rear wheel spinning when clutch disengaged.
Old Nov 7, 2010 | 09:34 PM
whoisthis's Avatar
Today, i had to check for exhaust leak so i jacked up all four corners on the jack stands.
I started up the engine and the rear wheels started spinning, not craazy fast but still fast enough to hurt you. If i press in the clutch, they don't spin no moaar. Is this normal?
I have stock clutch , ss clutch line and new clutch fluid, and i adjusted the clutch pedal so that it sits lower but not much. Could this adjustment cause it?
Old Nov 8, 2010 | 01:53 AM
AARONHL's Avatar
Yes, I've noticed that before. People here have said it's normal, that the clutch is always "rubbing" I guess you could say, and when the wheels are on the ground it's never enough to really keep the car moving.
Old Nov 8, 2010 | 02:03 AM
whoisthis's Avatar
Wouldn't this be dangerous when working on the car on the stand in a small garage? LOL
Old Nov 8, 2010 | 02:09 AM
AARONHL's Avatar
If you have it properly on jack stands and the front wheels blocked I don't see why it would be dangerous. Actually driving the car on the road would be more dangerous. Hahaha
Old Nov 8, 2010 | 10:04 AM
brandon1978's Avatar
When the clutch is engaged the input shaft (coming from the engine), the layshaft, and all of the gears are rotating at the same speed as the engine. The output shaft (going to the diff) is not mechanically engaged when the shifter is in neutral, but there is still enough friction to rotate it a bit. If you don't want the wheels to rotate, apply the parking brake.
Old Nov 8, 2010 | 10:09 AM
GeeWillikers's Avatar
Walking The Fine Line...
Engage ebrake?
Old Nov 8, 2010 | 12:08 PM
whoisthis's Avatar
ebrake would work lol
thanks.
Old Dec 21, 2010 | 11:44 PM
CBRworm's Avatar
20 Year Member
I've heard that is mostly from oil drag in the tranny. Ebrake works
rezendvous420
May 31, 2020 01:26 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Bean_VQ35DE
Jul 22, 2015 07:06 PM
