Its time for 3.5 or 3.6 rear gearing !!!
Old Nov 18, 2010 | 12:05 PM
  #136
Canadian's Avatar
Canada, eh?
Originally Posted by Tollboothwilley
Your CC should work fine since you both have the newer style TCM. Speedometer goes off the stub axles in the rear - I'll bet you money that is your problem.
Are you referring to my issue? I haven't been reading this whole thread - only issues that pertain to me.
Old Nov 18, 2010 | 12:30 PM
  #137
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by Canadian
If this is the case, would it be possible to somehow falsify a signal so that the ECU will not disable CC?
With a little R&D, absolutely.
Old Nov 18, 2010 | 02:22 PM
  #138
OCG35's Avatar
^^^ tricking the BSM is pita, I'm sure tricking the ECU is no easier... I wonder if it would be less hassle getting an ECU from an MT?
I'm sure a programmer could re-write and not have ECU expecting signal from TCM, but getting one to have the time (and willingness) might be impossible.
Old Nov 18, 2010 | 02:24 PM
  #139
Jeff92se's Avatar
Red Card Crew
Contact UpRev and see if they can dig into the code and change things?
Old Nov 18, 2010 | 05:37 PM
  #140
boostedforlife's Avatar
I already spoke with uprev,
Since my cruise control stopped working( i have no rear end swap)
in the email back to me, they mentioned that if you swap the rear end that the CC will stop working, and they have no work around for it.
Old Nov 18, 2010 | 05:43 PM
  #141
OCG35's Avatar
^^^ we've already established that switching rear fd doesn't mean you'll lose cc.
But expecting them to find a fix isnt going to happen - they are a small team of good people (with basically one programmer) that can barely keep up with the demand for existing ECU needs. There is no way they will take the time for something like this.
Old Nov 18, 2010 | 06:16 PM
  #142
NFSP G35's Avatar
? = 2B || !2B
It's just a hall effect sensor. Falsifying that should be pretty easy.
Old Nov 18, 2010 | 06:54 PM
  #143
yea I know we already know that, im just saying what they sent to me, and what I should have said what you said very nicely for me about them not being able to take the time to work on something like this
Old Nov 18, 2010 | 07:11 PM
  #144
OCG35's Avatar
sounds like you think you've got his problem solved - good luck with that
Old Nov 18, 2010 | 07:16 PM
  #145
Jeff92se's Avatar
Red Card Crew
I'm pretty sure he was talking to someone else unles you used similar stub axles?
You try the neutral brake switch thing yet? That would seem to be the easiest one try first. If you still think that might be one of the causes.
Time to get an ECU pinout for a 6mt and auto and start comparing them?
Old Nov 19, 2010 | 02:25 AM
  #146
Tollboothwilley's Avatar
NO, i was referring to the 2 people with the G37 pumpkin swaps.
The downside to tricking the ECU by doing this would be that in the event you need traction control to respond the computer won't realize there is a problem and therefore will not adjust as is designed.
Old Nov 19, 2010 | 08:25 AM
  #147
NFSP G35's Avatar
? = 2B || !2B
^Not necessarily.
If the stub axles have the wrong number of teeth on the wss, and you correct for that, you're actually helping correct the traction control that might otherwise not work.
Old Nov 19, 2010 | 12:47 PM
  #148
Canadian's Avatar
Canada, eh?
No, haven't tried it yet. Won't be able to for a couple of weeks, I don't have my car right now.
I'll do what I can with the shop once I get it back. I can't switch to a 6MT ECU because the 6MT ECU for my year is for a revup.
If I bought an older ECU it won't work properly because I have wideband o2 sensors and older years require narrowband sensors, from what I understand anyway.
Old Nov 19, 2010 | 04:46 PM
  #149
OCG35's Avatar
oh boy, ur in a pickle... how often do you use cc anyway? You might have to just pretend you have a Z with no cc...
Old Nov 19, 2010 | 06:05 PM
  #150
Canadian's Avatar
Canada, eh?
Yeah, so thats why I stayed with my stock ECU. I don't use CC that much, but I want it for map switching with uprev.
