Its time for 3.5 or 3.6 rear gearing !!!
Old Nov 20, 2010 | 11:50 PM
  #166
NFSP G35's Avatar
? = 2B || !2B
^DIY swap the pumpkin yourself. Much cheaper
Old Nov 21, 2010 | 12:19 AM
  #167
OCG35's Avatar
Originally Posted by 19kdrill
^Ouch, 2K? Not really willing to spend that much right now. But thanks for the replies though. Good info!
rob.g
you can probably get a used 3.5 w/vlsd for 500 or less... that's a decent option at a much lower price point.
Old Nov 21, 2010 | 12:33 AM
  #168
DaveB's Avatar
www.car-part.com
Search the term "carrier".
I got 3.5VLSD pumpkin for $330 from a local auto recycler.
Old Nov 21, 2010 | 12:51 AM
  #169
19kdrill's Avatar
Good stuff, ya'll. I'll check in to it.
Old Nov 21, 2010 | 01:11 PM
  #170
Tollboothwilley's Avatar
Originally Posted by Canadian
No, haven't tried it yet. Won't be able to for a couple of weeks, I don't have my car right now.
I'll do what I can with the shop once I get it back. I can't switch to a 6MT ECU because the 6MT ECU for my year is for a revup.
If I bought an older ECU it won't work properly because I have wideband o2 sensors and older years require narrowband sensors, from what I understand anyway.
Easy enough - you just swap O2 sensors and go with the 2004 6MT ECU.
Old Nov 21, 2010 | 01:15 PM
  #171
I've seen 3.5 FD w/ VLSD go for $400 Shipped regularly.
Old Nov 24, 2010 | 04:15 PM
  #172
OCG35's Avatar
Cool, would appreciate it if you could let me know. I'll check with UpRev next week.
Just spoke to Shawn Church - he says the base model Z guys get a cc steering wheel and wire it up (all Zs are cc capable)...
I asked him about this:
Originally Posted by seymore4
Uprev is in the process of developing both a module that plugs into the OBDII port to let you switch between maps, as well as an ap for phones that will let you change maps remotely, possibly tying it into the alarm so it automatically switches to the theft map when you arm the alarm, but as of now base owners are SOL.
found in this thread:
http://my350z.com/forum/tuning/50670...-question.html
he confirmed this to be true - but speculates 6 months (or more) out... he works closely with UpRev (and was just out there last week, they were at his place the week before) so I value his info and trust it to be true.
So in your case I guess the only option for now is cheap laptop or netbook and load different flashes as needed... until the tricks UpRev is working on come out.
Old Nov 24, 2010 | 04:50 PM
  #173
NFSP G35's Avatar
? = 2B || !2B
Sounds like a fantastic reason for a CarPC to me
Old Dec 31, 2010 | 09:33 PM
  #174
wolfpackdl90's Avatar
Originally Posted by DaveB
The short version. There are two different points from which the car calculates MPH, the wheel speed sensors on the differential and sensor on the driveshaft. The ECU compares the values, though we believe the true calculation comes from the wheel speed sensors because when you add gears, there's no speedometer error. If you change the gears, the sensor value on the driveshaft doesn't match up with that of the wheel sensors. If the difference becomes too great, the CC thinks there's a problem therefore it won't engage. The 3.69 gears cause this problem, at least in the 03/04 cars.
Is there not a tune/programmer to counter this issue? The reason i ask is because one of my boys that i work with just put bigger gears in his 05' Mustang GT, and he had to flash his ecu to calculate for the difference. Now the mph are accurate and cruise control works as well.....
Old Dec 31, 2010 | 09:47 PM
  #175
NFSP G35's Avatar
? = 2B || !2B
^No, there isn't.
The Mustang reads the VSS in the tailshaft for both the speedometer and cruise.
The G uses the wheel speed sensors for the speedometer, and both the WSS and VSS for the cruise.
Old Dec 31, 2010 | 09:51 PM
  #176
Originally Posted by NFSP G35
^No, there isn't.
oh ok, i appreciate you explaining that.....
Old Dec 31, 2010 | 09:55 PM
  #177
NFSP G35's Avatar
? = 2B || !2B
^If you read Dave's post very carefully, he explains that as well.
I just condensed it.
Old Dec 31, 2010 | 10:01 PM
  #178
kyemaul's Avatar
Today I intstalled a 2005 6mt 3.54 pumpkin in and I'm not having any problem with cc!!!
Old Jun 3, 2011 | 12:51 PM
  #179
Canadian's Avatar
Canada, eh?
I know this is an old thread but I thought I'd update..
Just got my car back and JWT flashed my ECU using their own software to a 2004 6MT 350Z ECU to tune the car and my CC now works. Glad it wasn't a big issue!
Old Jun 6, 2011 | 11:55 AM
  #180
JaE35's Avatar
Moderator
G35 Sedan
Why isn't this mod talked about much? I would expect to see it in signatures lol
