Its time for 3.5 or 3.6 rear gearing !!!
Old Nov 14, 2010 | 02:35 PM
Jairen's Avatar
Originally Posted by kyemaul
thanks, but what models including the coupe have the 3.5 and the vlsd. My uncle did a skyline conversion. He has the orginal vlsd 2004 g35 coupe A/T diff but i would like to know if it is 3.5 or not because it would be a free upgrade!!!!!!!
You need to get one from a 6MT.
Old Nov 14, 2010 | 02:37 PM
kyemaul's Avatar
When i do that will it bolt up directly?
Old Nov 14, 2010 | 02:39 PM
kyemaul's Avatar
And i was just told that the automatic g35 has a better gear ratio than the 6mt? Sound funny to me need some answers confused all over again...
Old Nov 14, 2010 | 06:06 PM
Mustang5L5's Avatar
Originally Posted by NFSP G35
As Dave said, no. Unfortunately, none of the tuning software addresses this issue as of yet, and it's questionable if they EVER will as it's not exactly "performance related"
Hmm, I wonder of that's because final drive swaps aren't common yet on the g35. Still, I'm amazed that not one single tuner has addressed this?
I know with mustangs, final drive swaps are a $200-300 job, so they are common. Speedometer pickup is electronic and off the trans and there are plenty of handheld tuners or custom tunes that can recall the speedo for final drive ratio, and different size tires.
Maybe demand hasn't quite given a reason fpr that support to develop for the g35/350z ?
Old Nov 14, 2010 | 06:08 PM
Mustang5L5's Avatar
Do the awd cars use a 3.7? I know they are open diff but thought imread they used the shorter final drive and not the 3.3. Or did they get 3.5?
Old Nov 14, 2010 | 07:19 PM
NFSP G35's Avatar
? = 2B || !2B
I think the reason nobody much messes with reprogramming for a new FD is because the speedometer works off the wss instead of the way a lot of other cars use the vss so if you change the FD on say an F-body, the speedometer is off, whereas if you change FD on a Z or G, you just lose cruise control, but the speedometer is still accurate
Old Nov 14, 2010 | 07:21 PM
Mustang5L5's Avatar
True, but that would drive me nuts. To me, that's a half-*** mod if you can't do it right....even if it's just cruise control.
Old Nov 14, 2010 | 08:16 PM
NFSP G35's Avatar
? = 2B || !2B
^Oh trust me, I agree.
Especially with the G35. If it was a track built 350z and you lost cc, big freakin woop.. but with a luxury sport sedan/coupe it should have cruise control.
Old Nov 14, 2010 | 08:43 PM
Bestswat's Avatar
2003-2006 AWD cars use 3.5 gearing. The 2007+ awd uses 3.7.
Old Nov 14, 2010 | 10:51 PM
OCG35's Avatar
Originally Posted by DaveB
The short version. There are two different points from which the car calculates MPH, the wheel speed sensors on the differential and sensor on the driveshaft. The ECU compares the values, though we believe the true calculation comes from the wheel speed sensors because when you add gears, there's no speedometer error. If you change the gears, the sensor value on the driveshaft doesn't match up with that of the wheel sensors. If the difference becomes too great, the CC thinks there's a problem therefore it won't engage. The 3.69 gears cause this problem, at least in the 03/04 cars.
I think sdgenious has an 03 w/ 3.7 and didnt lose cc... I have 04 (albeit half year car) and I didnt lose cc... there are others as well... why do you keep telling people it loses cc?
Old Nov 14, 2010 | 10:56 PM
SDGenius's Avatar
i have 3.7fd gears and i DO in fact have CC up to 80mph, after 80 it won't work but i'm fine with that since i wouldn't wanna ever do that anyway.
Old Nov 14, 2010 | 10:58 PM
OCG35's Avatar
I lose mine after 90... I've corrected Dave in the past, but he continues to tell people it loses cc.
Old Nov 14, 2010 | 11:01 PM
SDGenius's Avatar
i've noticed that... he really LOVES the 3.5 setup, i guess.
Old Nov 14, 2010 | 11:02 PM
NFSP G35's Avatar
? = 2B || !2B
Wasn't this discussed and we figured out if you exceed a certain point (such as 80 for Mark) and try to set the cruise, it disables it for the next 3 or so times you start the car? Or am I remembering wrong
Old Nov 14, 2010 | 11:05 PM
  #30
OCG35's Avatar
I can't speak for Mark - but that doesnt happen to me.
