Its time for 3.5 or 3.6 rear gearing !!!
Old Nov 14, 2010 | 11:10 PM
  #31
NFSP G35's Avatar
? = 2B || !2B
^I dunno.
There are potential differences between ones like Mine, Mark's, Chris' (03.0 with the old ecm) and the 03.5-04.0 with the newer ECM but older TCM and 04.5 like yours with the newer ECM and TCM
Mark, do you have a way to check the trouble codes (stored ones too) easily?
Old Nov 14, 2010 | 11:13 PM
  #32
naughty240's Avatar
Noob question but what does my 03 6mt have?
Old Nov 14, 2010 | 11:30 PM
  #33
kyemaul's Avatar
Originally Posted by SDGenius
i have 3.7fd gears and i DO in fact have CC up to 80mph, after 80 it won't work but i'm fine with that since i wouldn't wanna ever do that anyway.
Soo your 3.7fd how is the punch? they say 3.5 is a 6 to 7% increase in accel, how about the 3.7 is it a big difference? I heard with the 3.7 u can keep up with 07+ bmw 335i and 03 to 06 bmw M3 is that true?
Old Nov 14, 2010 | 11:35 PM
  #34
SDGenius's Avatar
i've beat a 335i and never raced an E46 M3 but i have a lot more than just gears.
Old Nov 15, 2010 | 12:04 AM
  #35
kyemaul's Avatar
Do You mind sharing ya mod list, or the ones that gave you the most power..!!! Always liked you G Sedan well done my friend!!!!!
Old Nov 15, 2010 | 12:06 AM
  #36
Tollboothwilley's Avatar
you should look in ENGINE, DRIVETRAIN, and TUNING section
This information has been hashed over MANY MANY TIMES
The reason for the CC not working is related to the Transmission Control Module. It compares values with the FD and thus will not allow CC to engage with values exceeding +/- 7% or so....which is the diff of the gearing
I lose CC function around 84-85 MPH. If I don't exceed that speed I can use the CC fine. Anytime I do exceed I must turn off the car for 10-15 sec and it will reset and I can use it again.
Old Nov 15, 2010 | 12:11 AM
  #37
SDGenius's Avatar
just click on my garage all my mods are listed there, thanks
Old Nov 15, 2010 | 12:18 AM
  #38
kyemaul's Avatar
Nice Mods list !!!
Im not to far off Time to race a 335i LOL..
So a 3.7 FD upgrade is a go for me. I dont want to CC above 80 anyway, if that is the only down fall im Sold!!!!!!!!!
Old Nov 15, 2010 | 12:36 AM
  #39
kyemaul's Avatar
with the 3.7fd is there anything i have to do when swapping this in. Any Resets Etc? is it a direct bolt on?
Old Nov 15, 2010 | 12:44 AM
  #40
SDGenius's Avatar
v36 6MT is a direct swap, v36 5AT needs to switch flanges and have a small piece ground down. do NOT take a diff of a v36 w/7AT they changed them back to 3.3
Old Nov 15, 2010 | 12:48 AM
  #41
OCG35's Avatar
you really need to spend some time researching... with a question like that it's clear you're not even sure what 3.7FD is.
Go the tech section of this forum - particularly drivetrain (for FD) - the other "power mods" you are after are in the tech forum as well. Those of us that did this mod years ago researched then asked questions that had not yet been answered (and in some cases just have to take a chance and try things based on logic). That makes the decision process less questionable and more satisfying. Try it.
Old Nov 15, 2010 | 12:54 AM
  #42
kyemaul's Avatar
i did my research on the 3.5 vlsd. but not the 3.7
Old Nov 15, 2010 | 12:55 AM
  #43
herrschaft's Avatar
Whoever has install questions:
https://g35driver.com/forums/drivetr...tial-swap.html
https://g35driver.com/forums/drivetr...-into-5at.html
Old Nov 15, 2010 | 12:56 AM
  #44
kyemaul's Avatar
So the v36 7a/t has a gear ratio of 3.3? if i understand what your saying
  #45
OCG35's Avatar
then why do you have this question:
