Paddle Shifters for G35 03 ?
Old Jan 13, 2011 | 03:20 AM
jutn35's Avatar
G35 Coupe
Question Paddle Shifters for G35 03 ?
I just found these online and it didnt say much about how to install them or what year they are for, im really interested in getting this.
http://intensepower.com/wobecopashin1.html\
Go to INFINITI G35>INTERIOR> WORKS BELL Column Shifter
thanks
Old Jan 13, 2011 | 03:26 AM
TORETTO's Avatar
https://g35driver.com/forums/g-spot/...-oem-look.html
Old Jan 13, 2011 | 03:40 AM
jutn35's Avatar
G35 Coupe
awesome , i jsut want to see diagrams and how to instructions so if i buy the kit ill just give it to my mechanic at infiniti and pay him to install it.
i want the OEM look too
Old Jan 13, 2011 | 09:56 AM
ride_002000's Avatar
Can you still use the normal automatic? Are they only able to be used when the shifter is over to the right for "manual mode" ?
Old Jan 13, 2011 | 08:17 PM
jutn35's Avatar
G35 Coupe
this ^ needs answers !
Old Jan 13, 2011 | 09:57 PM
CLEANBS's Avatar
is this a bolt on install? or is fabrication/drilling required?
Old Jan 13, 2011 | 11:17 PM
Canassis's Avatar
I have a paddle kit in mine. I use normal auto when on the phone, or just floating through town, and the paddles can only be used when the car is in sport manual. But yes, auto works fine, and the paddles, and the stick both work.
Need a vid?
Old Jan 14, 2011 | 12:11 AM
HavokGT's Avatar
Id personally like to delete the shifter on the center console completely and just have paddle shifters for P/N/D/1/2/3/4/5...
Anyone done this/attempt to do this/any ideas on how to go about this?
Would be the shietttt.
Old Jan 14, 2011 | 12:12 AM
TORETTO's Avatar
You forgot Reverse.
Old Jan 14, 2011 | 12:20 AM
Canassis's Avatar
You can't do it afaik. You need the rest of the transmission. Paddles only control drive gears 1-5.
fstasfk_G's Avatar
reverse = leg power lol
Old Jan 14, 2011 | 12:22 AM
HavokGT's Avatar
Winners never look bad... >_> hence the no reverse.
Look at my signiture
And it needs to be done.. will make the interior look so much cleaner...
Someone with an masters in engineering needs to get a move on it
Old Jan 14, 2011 | 12:24 AM
Canassis's Avatar
Bolt on w minor cutting.
Old Jan 14, 2011 | 12:29 AM
BigOgre's Avatar
Need a vid?
i want a vid!! lol Really I do..
Wait I sec, in that vid the guy was changing gears while the car wasnt moving. I know that the car is in tiptronic mode, but for my car I cant change the gear unless the car is over 2k rpm. Is this just a feature of the paddles?
Old Jan 14, 2011 | 12:32 AM
Canassis's Avatar
I saw that in the vid. It's an anomoly. I can't do it in mine, either. Must be the kit. I was sitting at a light tonight trying to shift just to make sure. Confirmed. No shift while stopped.
