*** correct way or fill 6-speed trans w/ gear oil ****
Old Feb 22, 2011 | 01:22 PM
856_reilly's Avatar
Hey guys, When I was pulling the trans out gear oil leaked out at the end. I'm looking for the correct way to replace, refill, and to know the correct amount or how to know if you have enough in there.. Any help would be great!!!
Old Feb 22, 2011 | 04:14 PM
superchargedg's Avatar
You fill it up in the fill hole after you remove the plug and keep filling it until it starts to come back out and your done.
Old Feb 22, 2011 | 04:57 PM
PhGit's Avatar
Might as well replace it unless you know it's fresh at this point. Remove fill plug first, then drain plug, just in case. I use the Mobil 1 75w-90 and like it. I highly recommend you get the pump that fits on top of those bottles... got mine at napa. Lots of pumping but makes it so much easier than any other way I can think of. 2 bottles (quarts) is about right if I remember correctly.
Old Feb 22, 2011 | 05:01 PM
PhGit's Avatar
oh... and the most important part, some plastic tubing... 5/16" ID I think. You'll want a good 2-3ft or maybe a bit longer so you can rest or at least shift around as you do it and not get oil all over the place.
Old Feb 22, 2011 | 06:12 PM
msommers's Avatar
You'll need 4 quarts to fill the transmission. I'd do a search and to decide what fluid to use but you can't go wrong with the OEM stuff.
Old Feb 22, 2011 | 06:52 PM
856_reilly's Avatar
Gotcha... Thanks guys....
Old Feb 22, 2011 | 09:49 PM
PhGit's Avatar
My bad! You wrote trans but I've was thinking rear diff all along. Yep OEM stuff is best in the trans and non-oem in the rear diff. I've read TONS on the fluids redline, amsoil, etc. etc.. and after all of it decided OEM was the best choice in a 6MT for the trans... still get the pump and hose unless you already have something.
Old Feb 22, 2011 | 10:45 PM
brandon1978's Avatar
Capacity is 3-1/8 US quarts. Since most but not all of the oil will be drained, 3 quarts should be plenty to fill it back up.
Old Feb 23, 2011 | 08:35 AM
856_reilly's Avatar
Cool Cool, The rear. Is there a drain plug on there as well? It's hard for me to just go outside and look. My car is like a hr. away..lol. What fluid do you guys suggest for the rear?
Old Feb 23, 2011 | 10:32 AM
PhGit's Avatar
I switched to Mobil1 75w90 and I'm happy with it. Some like Amsoil or Redline or Royal Purule but if you read enough posts about it you'll find people that don't like those too. For the cost and easy access to it, the Mobil1 works great for me... and I drive pretty hard.
Yeah, drain plug on bottom and fill plug higher up about 2/3 way up. Same way as doing the trans. I did both trans and rear diff at the same time since it's so similar and pretty easy with the pump and tube. just checked the tube... it is 5/16" and I've got maybe 14" sticking off the pump.. it worked well.
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
alessandro
Oct 8, 2015 09:29 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
NemesisGee
Aug 11, 2015 07:10 PM
