Transmission Shifting Roughly
Old May 11, 2011 | 05:52 PM
35G'dUp's Avatar
Most of the time while driving, when the car shifts from 1-2 while accelerating slowly the car will have a hard jerk. However, there are times when it shifts perfectly smooth, i figure if the transmission was faulty, it would shift bad all the time not just once in awhile, can anyone with similar problems chime in or give me some advice, worst case ill have to have the trans rebuilt or changed i suppose. Is it risky driving like this at all, it is only 1-2, if i shift it with the triptronic i can make it smooth, would that be a better way to go?
Old May 11, 2011 | 06:55 PM
Tollboothwilley's Avatar
a "hard" shift is not a bad thing - it generally is better than a "soft" shift because it has much less heat and heat is what kills a transmission.
What you are experiencing may well be a normal thing as well. When did you start noticing it?
If it is slipping before and then slammed into gear then you might be losing 1st or 2nd gear. If that is the case though, there is not much you can do, so you might as well just wait until something goes seriously wrong.
If it were me, I'd just drive it normal and if things worsen be ready to repair or replace the transmission. Might as well start a "transmission fund" for a rainy day - even if it never comes.
Old May 12, 2011 | 02:10 AM
WTF??'s Avatar
^ lol you sound like a doctor, "be prepared for open heart surgery"
Old May 12, 2011 | 12:32 PM
35G'dUp's Avatar
i noticed it after i bought it, during the test drive i didnt feel anything except perfect shifting, later i bought it and i was on the free way in traffic and i started to notice a jerk when shifting from 1-2
Old May 20, 2011 | 03:44 AM
jackjroadster's Avatar
there is not much you can do, so you might as well just wait until something goes seriously wrong then you have to find some cheap transmission then.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
KruZZe
Feb 27, 2023 05:04 PM
f22raptor
Mar 18, 2016 08:50 AM
RWDguy4238
Sep 30, 2015 12:13 AM
blnewt
Sep 25, 2015 01:48 PM
