04 6MT clutch/tranny issue
Old Nov 30, 2011 | 01:16 AM
SAMzG35's Avatar
G35
First i would like to say that i'm fairly new into the technical world of manual transmissions and if what i say don't make any sense, give me a break.
Driving my 04 G35 last few days its been feeling pretty weird, its kinda gutless & also gas mileage is poop. Every time I switch gears it feels like the car is barely moving but the engine is revving up. Lets say if I'm going 30 km/h and I throw it 5th gear and I hit the gas pedal half way the RPM jumps to 4 or 5k RPM and the car barely moves. Today i decided to see if i can stall it. I started letting go of the clutch slowly and when I was all the way off the RPM started slowly dropping to 0 right before it shuts off i pressed it again and she revved back up to idle.
Now reading/searching online i saw few things. One of them that might be my issue:
#1, Cheaper way. My clutch might be too loose and if i tighten the clutch a turn maybe turn and a half it might help (my engaging/disengaging point is right before the end of releasing the pedal, not even an inch or so)?
#2, My clutch is gone, i need a new one?
Other info i found & didn't know is clutch fluid (i know i'm retarded, but only had the car for 2 weeks and this is the first manual car i own, i drove many before though). So could that be an issue?
The car is an 04 with 98k km (58k miles???) I'm pretty sure clutch was never changed, still factory one. Car still shifts very smoothly between all gears and i have no problem going into any gear
Any help is greatly appreciated.
Sammy K.
Old Nov 30, 2011 | 10:39 AM
Z1Motorsports's Avatar
Sounds like your clutch is shot. Your not going to be able to adjust out that problem, depending on how they have been treated the average stock clutch lasts 60k-100k miles.
Let me know if I can help you with anything,
-Rob
Old Nov 30, 2011 | 11:27 AM
Texasscout's Avatar
Yep, clutch is shot. One of the Sponsors here on the forum. You can get anything from stock to full race clutch packs here.
Get ready to fork out over a grand also.
Old Nov 30, 2011 | 11:55 AM
SAMzG35's Avatar
G35
being in fort mc im pretty sure its way more than a grand, average shop charged 180+ per hour.
Any suggestions on clutches? whether to get OEM or after market? Price wise whats the best bang for my buck kinda clutch
Old Nov 30, 2011 | 12:11 PM
Best bang for your buck would be our Clutch/Flywheel combo, I do not recommend reusing the OE flywheel. Our package can be found HERE
Wow, $180 an hour!?! That's insane.
-Rob
Old Nov 30, 2011 | 12:22 PM
Texasscout's Avatar
I used a Jim Wolf Technology clutch package (Lightened flywheel, clutch element, pressure plate, throw out bearning, stainless steel clutch line, and bearing insert) for about $800 and the labor made it all about $1200. Ordered from www.importpartspro.com one of the site sponsors.
Old Nov 30, 2011 | 01:19 PM
AARONHL's Avatar
Wow, too bad the previous owner didn't tell you the clutch was going...something like that doesn't happen in two weeks.
Old Nov 30, 2011 | 01:33 PM
faiz23's Avatar
Read the million threads on clutches and see what to do. I would shop around and only pay max of $500 in labor for clutch. I have already sourced out shops that will do it for $300-350 and friend who has done 12-13 clutch jobs on G35/350z and should be a little lower / some booze
$775 for clutch kit with all parts minus fluid.
https://g35driver.com/forums/engine-...-shipping.html
MAX LABOR $500.
https://g35driver.com/forums/dfw-cla...-specials.html
Old Nov 30, 2011 | 02:44 PM
Texasscout's Avatar
That's the one I ordered. It cost $400 to install.
Old Nov 30, 2011 | 04:07 PM
SAMzG35's Avatar
G35
i had the JWT in mind but i read something online about them changing their clutches and they are not the same ones they used to carry, not sure how legit this is.
As for labour, i called two places and was quoted approx $1100.00 bucks!! just for labour. Labour was $189.95 an hour at one place and the other was $195.00
isnt that insane?
Old Nov 30, 2011 | 04:24 PM
Texasscout's Avatar
Yes! That's nutz.
Old Dec 2, 2011 | 02:14 AM
SAMzG35's Avatar
G35
before i go ahead and order my clutch i just wanted to confirm this
any ideas/thoughts?
Old Dec 2, 2011 | 02:40 AM
Songle6MT's Avatar
Yikes, that would be a bad clutch
Old Dec 2, 2011 | 02:55 AM
SAMzG35's Avatar
G35
so clutch for sure correct?
you think tranny is fine?
Old Dec 2, 2011 | 07:34 AM
Clutch without a doubt, our transmissions don't fail like that anyway. The only real issue you will have with a G/Z Transmission is bad syncros (unless you powershift into 3rd with +500ft-lb ) SP made 1248rwhp through their stock Z Transmission.
-Rob
