sudden loss of power. motor is not climbing rpms quick. any ideas as to why?
Mar 22, 2012 | 11:51 AM
modds k&n intake kinetix intake manifold high flow cats n hks exhaust. motor is running real lazy. it has no power
Reply 0
Apr 30, 2012 | 01:33 PM
Check your charging system
Reply 0
May 1, 2012 | 07:37 PM
are you throwing any codes?
Reply 0
Jul 30, 2012 | 10:08 PM
U mean my battery?
Quote: Check your charging system
Reply 0
Jul 30, 2012 | 10:09 PM
Quote: are you throwing any codes?
No codes at all and this is driving me crazy. My friend had similar problems and his has to replace the cam shaft position sensor. But he had a code mine isn't throwing a code
Reply 0
Jul 31, 2012 | 01:26 AM
Are you manual? If so, sounds like your clutch is toast!
Reply 0
Jul 31, 2012 | 02:02 AM
what's your oil level?
Reply 0
Jul 31, 2012 | 06:55 AM
Quote: Are you manual? If so, sounds like your clutch is toast!
I'm auto
Reply 0
Jul 31, 2012 | 06:58 AM
Quote: what's your oil level?
Oil level is good to
Reply 0
Jul 31, 2012 | 08:14 AM
get it hooked to a scanner, i just went through this with mine, lazy motor and drop in fuel eco no engine light. got a scanner and it had a p0327 code. this is your knock sensor but most time on our motors its the harness. i just replaced my sensor this weekend, fixed the issue, came back on way to work this morning. i'm going to order the harness now.
Reply 0
Jul 31, 2012 | 01:17 PM
Quote: get it hooked to a scanner, i just went through this with mine, lazy motor and drop in fuel eco no engine light. got a scanner and it had a p0327 code. this is your knock sensor but most time on our motors its the harness. i just replaced my sensor this weekend, fixed the issue, came back on way to work this morning. i'm going to order the harness now.
Ok I'll try that thanks!. No this knock sensor or harness is it easy ti get to or will I have to get it professionally done?also how much money am I looking at
Reply 0
Aug 1, 2012 | 08:19 AM
it was really easy to get to, but alot of bolts to deal with. the intakes have to come off and the fuel rail and injectors can come off and be set to the side without disconnecting the fuel lines. you may want to also grab a set of orings for your injectors too if you have some miles on the car. i had one in really bad shape.
it took me about 1.5 hrs too pull it all apart taking my time and being careful, and about 30min to put it back together.
Reply 0
Aug 1, 2012 | 10:50 AM
Quote: it was really easy to get to, but alot of bolts to deal with. the intakes have to come off and the fuel rail and injectors can come off and be set to the side without disconnecting the fuel lines. you may want to also grab a set of orings for your injectors too if you have some miles on the car. i had one in really bad shape.
I already took my upper and lower plenums off and put in the kinetix ssv intake manifold. So really all I would have to do is UN bolt it and work with moving the fuel rail?
Reply 0
Aug 1, 2012 | 12:21 PM
I hooked up a scanner to the car and got that' same code. I went AutoZone looking to buy the scanner and they said they had one for $30 and one for $140. Also they said they didn't have the harness. Were did u order ur parts from? I want to make sure I get the right parts
Reply 0
Aug 1, 2012 | 12:39 PM
Also infiniti gave me a price of $230 for the knock sensor and 103 for the harness. And it's weird because he said there's no part named ks harness he said they were named wiring 1 2 and 3 and he looked up the one that was for my car. Were did u guys get yours from
Reply 0
