Swapping out clutch and flywheel, what else?
Old Apr 19, 2012 | 05:28 PM
tt awd's Avatar
Pretty basic question, im about to get my stock clutch and flywheel swapped out for a Z1 mild performance clutch and ACT streetlite flywheel. I was just wondering if theres anything else i should do at the same time?
My pedal does stick halfway up so im thinking its the right time to replace the master slave cylinder as well? Is that correct? Is there anything else i should be changing?
Thanks for the help!
Old Apr 21, 2012 | 03:27 PM
TunaG35's Avatar
ive kinda got the same issue, everyonce in a while my clutch pedal will stick half way up and half way down while im driving normally, and when i try to roast the tires (this happens rarely) but when i go to pop the clutch, the pedal will just stick to the floor and ill accelerate, but not like a vq should, more like a tercel does...any ideas on what happens?
Old Apr 22, 2012 | 06:36 PM
tt awd's Avatar
Theres a lot of stuff on this. Most say its the clutch slave cylinder while others say to change out the fluid.
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
doakley92
Sep 25, 2015 12:58 PM
