Carbonetic LSD whining under acceleration
Old Jul 5, 2012 | 08:44 AM
DVG's Avatar
DVG
Exclamation Carbonetic LSD whining under acceleration
I have a Carbonetic clutch-type LSD installed on my car. It was very quiet and nice for the first month or 2 I had the car, but then it began to make clicking noises when I turned. I promptly had the oil changed.
Ever since, it has made a whining noise under acceleration. It is somewhat annoying, but I can live with it, I was wondering though, is it something I should be worried about?
I didnt get the oil changed after breaking it in. The diff was pre-used so I figured it had already been broken in (stupid, I know.)
Fixable?
Thanks
Old Jul 5, 2012 | 11:20 AM
rcdash's Avatar
Carbonetic ATS LSD calls for fluid changes every 1800 miles. Believe it or not. I replaced mine with a Quaife to get rid of the maintenance issues. I believe the carbon debris ends up gradually changing clearances through wear and tear. Replace bearings and set backlash and it should be back to normal, for awhile.
Old Jul 16, 2012 | 09:27 AM
DVG's Avatar
DVG
Wow - I cant do every 1800 miles lol
Do you know where I can get the parts to do that? Or how much approx they will cost? Are bearings part of the diff, or part of the pumpkin?
I am thinking about getting a quaife too. Do you know if it will be drop in ready? My car is a 2003 5AT but I believe the SG motorsport swapped out the pumpkin with a VLSD-equipped one during the install.
I will be doing this swap myself hopefully.
06g35
Feb 14, 2022 05:59 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
