Tranny problem? Help!
Old May 23, 2013 | 10:28 AM
johnnyqt25's Avatar
Hi all, I have a big problem with automatic transmission. Car has hard time changing gears. It seems to stay on first gear and RPM goes to like 7000, before going into other gears. I took it to a repair shop and they said the tranny is shot and it will cost me about $2000 to replace, but I'm not sure if I believe them. They also used a code reader for the check engine light, but it's some kind of sensor unrelated to the tranny problem. Should I flush and put new transmission fluid first? Any suggestion would be greatly appreciated before I spend $2000.
Old May 23, 2013 | 12:00 PM
JKL1031's Avatar
ur not a noob throwing it into sportronic without knowing are you? O.o
Sounds more like a solenoid or stuck in sport mode problem to me. Dont think sport mode lets u ride the limiter in any gear and over rides bad commands like over revving. Well then all ur other gears would do the same. Someone correct me if im wrong.
Take it somewhere else.
Old May 23, 2013 | 03:38 PM
johnnyqt25's Avatar
No, I'm not throwing it into sportronic.
Old May 24, 2013 | 01:11 AM
rsingerG35's Avatar
When was the last time the fluid was checked?
Thebaws11
Jul 2, 2021 11:36 AM
wuzz-upp
Oct 3, 2015 04:21 PM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
DRG35R
Sep 16, 2015 05:33 AM
mattdg35
Sep 14, 2015 11:28 AM
