5AT using Koyo help..
Old Jul 8, 2013 | 06:14 PM
ekrebs's Avatar
So i tried searching but cant seem to find my answer. i have an 05 5AT which im installing the Koyo radiator for the manual's. I know i need to run a tranny cooler but how do i route the hoses since the manual radiator doesnt have the tranny lines? do i run it right to tranny? Thanks
Old Jul 8, 2013 | 07:07 PM
GR6RR's Avatar
I would return it and get the right one for your AT...
Old Jul 8, 2013 | 07:13 PM
ekrebs's Avatar
They dont make a Koyo for auto. Other members have done what im doing but I just dont know about the hoses. Thanks
Old Jul 8, 2013 | 10:57 PM
bigc's Avatar
Wings Nation
yeah, you just connect the transmission to the cooler directly. the stock transmission hardlines stick out under the front of the engine. connect those lines to your cooler. some folks just use a bunch of clamps to secure the cooler lines to the hard transmission lines, but the best thing to do is use compression fittings since the fluid in those lines is under a decent amount of pressure.
Old Jul 8, 2013 | 11:05 PM
ekrebs's Avatar
Thanks..also would I just reference the oem radiator ports and match them up to cooler ports?
Old Jul 9, 2013 | 01:45 AM
bigc's Avatar
Wings Nation
yeah, the OEM hardlines are like 5/16" or 3/8" diameter if i remember correctly.
Old Jul 12, 2013 | 10:28 AM
ekrebs's Avatar
Let me rephrase my last question.. in regards to the "in and out" ports on the tranny cooler should i just referrence the tranny ports on the OEM radiator? Thanks
Old Jul 12, 2013 | 04:35 PM
bigc's Avatar
Wings Nation
Yes, you can do that (they should be roughly the same size), but since the ports on the OEM radiator are no longer a factor in your new cooling system, you need to be focused on matching up your new lines and cooler with the OEM hardlines.
Old Jul 12, 2013 | 05:11 PM
ekrebs's Avatar
Any way you can be more specific on what you mean by matching up the new with oem lines? I read on another forum that sice im bypassing the rad that it doesnt matter whic way I hook up the cooler since its an in and out system. Is this accurate? Thanks again
Dat Kid
Nov 23, 2015 11:18 AM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
TrillO.G.35
Sep 5, 2015 02:06 AM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
socalg35x
Jul 28, 2015 10:42 AM
