Transgo shift kit
Old Oct 21, 2013 | 03:34 PM
Joonn's Avatar
Transgo shift kit
Alright so I've been looking around and found this
https://www.gtmotorsports.com/produc...cat=345&page=1
now it says full kit for $280 but doesn't show whats inside than I was on
http://www.summitracing.com/search/b...rder=Ascending
and this website had others for a different range of price. What would I really need for my G35? I'm not sure exactly what I need for the upgrade. Anyone able to help me here
Old Oct 21, 2013 | 10:43 PM
jdm-v35's Avatar
The kit itself usually runs about $300. I bought mine from GTM also as its the one needed for the G35. Be aware that that in the box is only a bunch of pistons, springs, ball bearings, drill bits and gaskets needed for this but unless you have experience taking apart a trans labor for this install is usually about $400 and I wouldnt recommend even attempting to do it yourself unless you really know what you're doing as you can really mess things up.
Also with this you should probably install a trans cooler at the same time. Most people do it with the transgo kit and I did aswell.
Old Oct 21, 2013 | 10:53 PM
herrschaft's Avatar
That is for a different transmission, this is the right one http://www.summitracing.com/parts/tr...-hd2/overview/.
Old Oct 21, 2013 | 10:58 PM
seymore4's Avatar
m56
Get it off Summit. best price around
Old Oct 21, 2013 | 11:09 PM
danoman32's Avatar
Here's a DIY, it's not that difficult, just take your time.
https://g35driver.com/forums/engine-...y-upgrade.html
Old Oct 21, 2013 | 11:31 PM
Joonn's Avatar
I'm actually taking an automotive class and our next class is transmission work so I think I would be fine? I also confirmed with the instructor and he was cool with me working on that and he does have experience with shift kits. So the full kit would cost around $300 and not like $100 or around $180?
Old Oct 21, 2013 | 11:49 PM
Joonn's Avatar
what is the difference between these two kit?
Old Oct 22, 2013 | 10:41 AM
seymore4's Avatar
m56
Click on the link that was provided and you will see exactly how much it costs.
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
