Rear Tire Spinning whe exiting coners
I'm not sure what's going on in this thread, but for the OP breaking loose in the turns, and open diff is going to do that period. Look for a used LSD at a minimum. You have several factory rear gear ratios to choose from in your search: 3.3 came in with the AT, 3.5 came with the 6MT, and 3.7 is available in the G37/370Z 6MT.
Upgrade to an LSD and enjoy the increased traction. Then start upgrading other stuff as needed.
Yes, Rear End seems place to start. THAT is why I came here asking about people's EXPERIENCE.
Thank you guys so much for showing up.
My tires are fine....It is the car set up that needs improvement.
The nut behind the wheel knows well where the Apex is and what to do when.
I currently do not have a race car and want to dabble in Auto Cross a bit, again. I'd like the dang car to be safe on the street too.
Thank you all so much....Now just to locate a Rear End for my G.
But hey, you know it all and have heard the answers you like so I'll shut up now.
I stopped posting because I've got better things to do other than arguing with someone who apparently hasn't graduated high school yet.
Come on kid, post some pics or vids of your awesome racing machine in action.
Is that really supposed to be an insult coming from someone who can't even manage to drive their own car??? If it really takes "experience" to tell you how an open differential works than...
For anybody else with this issue of loose rear end exiting corners.
Turn off VDC...It helps quite a bit. Stops the just the inside wheel spinning so much BS.
You guys have been so helpful as usual.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
