speed sensor?
Old Oct 30, 2017 | 09:19 AM
TNight's Avatar
speed sensor?
Is there a difference between the wheel Speed Sensor and Vehicle Speed Sensor?
Getting conflicting Info
Old Oct 30, 2017 | 09:42 AM
LoSt180's Avatar
Yes, but they're related.
The wheel speed sensors are the physical sensors in the wheels (front hubs, or diff output shafts on the rear) and are wired to the ABS/VDC/TCS computer.
The ABS/VDC/TCS computer uses these readings for ABS things, but also outputs the vehicle speed to the cluster via CANBUS, the cluster then sends the signal to the ECU.
Old Oct 30, 2017 | 03:12 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The vehicle speed sensors are mounted on the rear axle, one one each side and control the signal sent to the speedometer gauge.
dsheldon924
Jun 27, 2017 07:26 PM
Gozer
Apr 17, 2017 12:26 PM
J_buwalda
Oct 19, 2016 02:08 PM
Gabe35Coupe
Jul 28, 2014 01:34 PM
