Differention and transmission fluid opinion
Received 2,458 Likes
on
Coupe 6MT Premium RAS
FreshLikeAG (02-07-2018)
on
on
Interesting read.
My service adviser at infiniti had never heard of power flushes causing problems in RARE cases. I later found out that he was not trustworthy after screwing me on a service I didn't need. That dealer has some serious corruption going on. I bet if I paid for the service they would just do a drain and fill instead of a flush for over $200. The only thing they would flush is my wallet!
on
Nothing like creating a problem where one did not exist.
https://g35driver.com/forums/g35-sed...ml#post7129287
Telcoman
Telcoman
on
Each planetary gear inside your AT has a wet clutch pack and a brake sleeve that are wearable components. As they wear the debris washes through the transmission and eventually catches in the filter. All hydraulic fluid breaks down from use especially from heat while under a heavy load. A drain/fill removes particles as well as replaced worn fluid. Nearly all transmission failures and problems are simply from not servicing the thing on interval. It's a big expensive component when it does go out .
on
Telcoman
Telcoman
People skip a tooth on timing chain replacements all the time. Is that the timing chains fault or the person who did the work?
twin001
71
04-21-2015 08:16 PM
Nissan420sx
09-04-2014 07:47 AM
