Ticking noise at idle after head gasket and new chain
Old Feb 14, 2018 | 10:26 AM
bash.blah Blah's Avatar
https://youtu.be/skmbqFBkxGI here is a video of the noise
Old Feb 14, 2018 | 10:46 AM
Any help would be appreciated. Would an exhaust cam starving for oil possibly sound like this?
Old Feb 14, 2018 | 11:02 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
That sounds terrible, did you keep track 100% of which lifter bucket goes with which valve? Did you use NEW head bolts (oem ones are torque to yield which is good for a SINGLE use).
Did you add oil?
Old Feb 14, 2018 | 11:10 AM
Did you add oil?
All new head bolts. All buckets were kept on place. Head bolts by the book. Timing marks all lined up
Old Feb 14, 2018 | 11:12 AM
Heads were decked at machine shop
Old Feb 14, 2018 | 11:27 AM
cleric670's Avatar
BANNED!!!
How did you keep the buckets in place when they decked the heads? Did you leave the cams installed??
Old Feb 14, 2018 | 11:32 AM
cleric670's Avatar
BANNED!!!
If it were mine I'd start with a stethoscope to narrow down exactly where the sound is coming from but I have a feeling you'll be removing the valve covers to reinspect the work. Exactly which head gasket did you use?
Old Feb 14, 2018 | 11:54 AM
Itm head gasket. I removed cams but I talked to guy at machine shop when I dropped then off he assured me they wouldn't be move. It was manually washed instead of parts washer for that reason.
Old Feb 14, 2018 | 12:54 PM
cleric670's Avatar
BANNED!!!
Then I'd start by checking clearances on the cam buckets, .30mm for intake .33mm for exhaust, chances are you'll find the problem, hopefully there wasn't debris that washed under one of the buckets. Did you remove and inspect them all after you got the heads back?
Old Feb 14, 2018 | 01:46 PM
I inspected before putting cams in and used engine lube on cams. Would a vct cam make that noise. I also bought new vct gaskets when I did this
Old Feb 14, 2018 | 02:12 PM
cleric670's Avatar
BANNED!!!
I'd start with the mechanics stethoscope so you can narrow down exactly where the sound is coming from.
Jbl_91762
Jan 23, 2017 09:11 PM
Hi-TechG35
19
Sep 24, 2014 09:15 PM
TwilightG35Guy
Aug 10, 2009 10:09 AM
G35 Mass
Jul 22, 2006 12:14 PM
