Rear differential
Old Apr 7, 2019 | 08:02 PM
Cosworthy's Avatar
04 G35 rwd 6mt, 04 g35x, 05 g35x, 02 q45
Rear differential
Hello everyone, I have a 04 6mt g35 sedan and I want to switch out the ring and pinion for the 4.083 and haven't had any luck finding a used rear diff with it already installed and the closest shop to me that I would trust is 110 miles away and wants 2k parts and labor. Does any one have a diy on this so I can do it myself?
Old Apr 7, 2019 | 08:59 PM
Pbfoot's Avatar
04 G35 Sedan performance package. 70k Eibach springs and sway bars. 19 inch wheels. Plenum spacer.
https://www.z1motorsports.com/transm...36-p-4523.html. About 800 for parts. Not impossible for an above average shade tree mechanic. Requires setting proper clearances and preload as well as correct tooth contact or the unit will quickly destroy itself.
Old Apr 7, 2019 | 09:13 PM
Cosworthy's Avatar
Doing everything correctly is what's making me nervous about the install.
Old Apr 7, 2019 | 09:18 PM
Pbfoot's Avatar
Correct tooth contact is set by shims on the pinion gear. Differential side bearings are adjustable left and right for proper clearance. Watch some videos read the service manual. Then decide. Keep searching for a used unit.
Old Apr 8, 2019 | 12:25 PM
Cosworthy's Avatar
I appreciate the advice, I'll do some more reading and researching then fo from there.
pissout
Mar 15, 2005 03:41 PM
G35_TX
Drivetrain
30
Nov 22, 2004 02:58 PM
mikeinaustin
Apr 3, 2004 03:40 PM
tonke73
Drivetrain
Mar 31, 2003 07:58 AM
himura816
Drivetrain
Jan 22, 2003 03:38 PM
