First post... need help with steering.
First off I know I’m probably on the wrong forum and I’m sorry if you know where I need to go I would gladly take directions. But I have an 04 G35 and I need the lower steering shaft and u joint replaced but idk where to get the shaft anymore. I tried calling the dealership and they told me that the part has been discontinued and now I don’t know what to do. Any help would be greatly appreciated
Are you sure you need to replace the shaft? Normally it's only the u-joint that needs fixin'.
The u-joint is not a discontinued part, Nissan part number 48080-AG30A
The rest of the components for the steering column ARE discontinued, your best bet would be eBay or a local pick-n-pull.
07 G35 stuttering and dies. ECM?
Hi Guy,
My G35x is stuttering and shutting off when I turn it on. Said it was an O2 sensor I changed it. Going to clean out the throttlebody next and MAF sensor. Will also change the plugs. Does anyone know where I can buy an ECM with the Nats bypass? Or am I going the wrong entire way?
greek211
Dec 16, 2007 02:22 PM
greek211
Jan 21, 2007 02:39 AM
