steering vibration of my car, help guys??
Old Dec 15, 2007 | 11:09 PM
greek211's Avatar
hi ,guys,
i find my g coue ( 65000 k) have more stronger steering vibration when A/C is on . it gets worse when the day get cold. if i turn off the A/C, then ,there is np at all. anyone can give me some suggestions.
Old Dec 15, 2007 | 11:13 PM
bigc's Avatar
Wings Nation
steering vibration is usually a sign of wheels out of balance. wierd that you only notice it when the A/C is on...
Old Dec 15, 2007 | 11:14 PM
greek211's Avatar
yes, it always happen in idle.
Old Dec 15, 2007 | 11:30 PM
greek211's Avatar
help?
Old Dec 16, 2007 | 01:05 AM
TheG35Dude's Avatar
If the vibration in the steering wheel get worse with an increase in speed your tires need balancing. Speed + more vibration = wheel balance bad.
If it vibrates at idle something may be wrong with your power steering. Maybe a loose pulley or broken tensioner since loading the belt by turning on the ac changes things.
I don't understand whats happening, so with AC on there is more vibration; is it the engine that is vibrating, shaking the whole car or is it just the steering wheel ?
gotta feed us some more info.
Old Dec 16, 2007 | 02:15 AM
greek211's Avatar
it is just the steering wheel is shaking
Old Dec 16, 2007 | 08:47 AM
g35rcr's Avatar
if its under warranty take it to the dealer thats why you have a warranty
Old Dec 16, 2007 | 09:50 AM
Jason@Riverside's Avatar
at idle?
have you looked under the hood while your car is at idle and the wheel is vibrating?
Old Dec 16, 2007 | 12:28 PM
TheG35Dude's Avatar
Very weird, so when parked at idle there is a vibration threw the steering wheel, If so I would look at the power steering system, also check the power steering fluid level.
Old Dec 16, 2007 | 02:22 PM
05GCOUPE6MT's Avatar
If at idle it can be ***allot*** of things. Do you have an engine damper. Could be dirty injectors or carbon build up. Put a can of Chevron Tectron 20 Gallon treatment in along with a dry gas. Could be a dirty sensor such as the MAF or faulty or damaged O2 sensor [did you put in an aftermarket exhaust or cats]. Even a dirty gas filter, air filter or plugs could cause it. You may have to have someone diagnose it, but first I would start with a good cleaner.
Mry
Mar 3, 2023 01:03 AM
bTanz
Oct 15, 2015 02:31 PM
Frostbite91
Jul 27, 2015 05:25 AM
itschuckster
Jul 25, 2015 08:07 AM
Karnicle
Jul 23, 2015 05:08 AM
