Clutch fork/Pivot ball issue
Old Aug 5, 2021 | 09:50 AM
04G35inKY's Avatar
2004 G35 coupe obsidian black, 18" Konig SSM rims, KW coil overs. Brembo brakes, JMT cold air intake
Hi I recently purchased a clutch kit from Zspeed for my 2004 g35 coupe and I have a question when I installed the new clutch, throw-out bearing flywheel and bolted the transmission back up I forgot to attach the fork to the pivot ball, it is the solid clutch fork that has the shorter pivot ball, will this most likely pop into place when I start depressing the clutch or do you think I need to tear everything back apart? or is there a recommended way to do it while still together? Any help would be greatly appreciated. Thanks
Old Aug 5, 2021 | 09:20 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You can snap it onto the ball from the outside of the transmission, just remove that rubber boot and use a flat screwdriver wedged against the housing to leverage the fork onto the pivot ball.
The rubber boot has an arrow pointing forward so pay attention to it's orientation when you remove it.
Old Aug 6, 2021 | 06:52 AM
04G35inKY's Avatar
Awesome thanks for the reply. I was able to get the boot off and and get a look and it had snapped in to place so I'm good to go , thanks again.
OnemeanG
Drivetrain
35
Jun 26, 2021 04:16 PM
maxpusher
Oct 19, 2012 06:15 AM
metpage
Aug 15, 2009 10:10 PM
marc22411
Florida G Club
Dec 23, 2006 08:58 AM
