I have a 2004 g35 manual and every time I step on the clutch I can hear a squeak and the engine dies the squeak kinda sounds like a throw out bearing but I don’t understand the engine stalling I was reading online and heard a lot about “crank walk” when your thrust bearings are bad causing your crankshaft to have play in it I read that can cause stalling when you push in the clutch so I recorded my crank pulley while I pushed the clutch to see if there was any movement I could not see any movement I will attach the video I made you can hear the squeak and my engine dying out as-well as the pulley I would just like some thoughts on what it could be
cleric670
BANNED!!!
close
- Join DateMay 2017
- LocationWashington State
iTrader Positive Feedback0
iTrader Feedback Score(0)
- My RideCoupe 6MT Premium RAS
Liked:2,497 Times in 2,182 Posts
These engines don't have crank walk issues, some engines do, the VQ engines do not.
You probably have a bound up throwout bearing that's putting a lot of drag on the engine and stalling it, and creating a hellacious noise at the same time.
Thanks for the info you were correct took the clutch apart and throw out bearing was broken in half
Urbanengineer
close
- Join DateJun 2013
- LocationOH-IO
iTrader Positive Feedback100
iTrader Feedback Score(3)
Liked:1,044 Times in 959 Posts
Thrust bearing went booooooom! Thrust bearing walk!
cleric670
BANNED!!!
close
- Join DateMay 2017
Back in the early 2000s I had two friends with late 90 Eagle Talons and one friend with a 2000 Eclipse and my youngest brother had a early 90's Eclipse. All had the turbo 4G63, I know all about those thrust bearings LITERALLY FALLING OUT.
