Tranny Gear Ratios.
Old May 25, 2003 | 09:04 AM
Msedanman's Avatar
O.F. Administrator
Tranny Gear Ratios.
I've read the transmission gears ratios for both the A/T and the 6 M/T somewhere, but can't find them at the moment. Would someone 'in the know' please post. TIA. [img]/w3timages/icons/smile.gif[/img]
<font color=green>GSM</font color=green>
Old May 25, 2003 | 09:57 AM
RamboRami's Avatar
G35driver.com Moderator
Re: Tranny Gear Ratios.
6MT:
1 - 3.79
2 - 2.32
3 - 1.62
4 - 1.27
5 - 1.00
6 - 0.79
Old May 25, 2003 | 12:47 PM
Msedanman's Avatar
O.F. Administrator
Thanks bro, Do you have the A/T ratios too so I can compare?
TIA..
Old May 25, 2003 | 01:51 PM
Msedanman's Avatar
O.F. Administrator
You can learn how well it's geared for low speed or high speed. I would prefer a low gear (high number) for quick acceleration down low. As Rambo has posted the Coupe's 1st gear is 3.79/1 which is quite low geared for quick take-offs.
The A/T gears are fewer and not as good--- 1st is probably in the 2.75-3/1 area, therefore not so quick off the line.
The other thing that affects performance is the rear gear ratio. The A/T's rear gear is about 3.3/1 whereas the M/T's is about 3.5/1-- again advantage manual tranny for quicker take-offs.
If you know the ratios in the tranny, you can improve things by changing out the rear gear to a numerically higher gear for example a 4/1 or even 5/1 for improved acceleration.
The down side of this is that the engine revs much higher and fuel economy and comfort suffer.
Old May 25, 2003 | 04:37 PM
Msedanman's Avatar
O.F. Administrator
Thanks dude, I appreciate the help. [img]/w3timages/icons/smile.gif[/img]
Old May 25, 2003 | 07:39 PM
Meatshackle's Avatar
Deep Sea Moderator
It tells you that our 6mt's are geared so that only 6th is overdrive. In most 6 speeds the 5 and 6 are overdrive. You can tell the difference in our 5th gear because it still has quite a bit of pull.
Russ
Black w/willow, 6MT, premium, nav, & aero
Old May 26, 2003 | 05:33 PM
Marcel's Avatar
speaking of gear ratios. It would be nice to have an even longer 6th gear. Cruising in 6th at 70-75 puts right around 2500. if we could get that down even another 500+rpms we would see some real nice gas savings on our long road trips.
Old May 26, 2003 | 05:44 PM
Msedanman's Avatar
O.F. Administrator
Hey they're making a 7 speed auto now, why not a 7 speed M/T? Then you could have 2 overdriven gears. That's a lot of shifting for a manual. [img]/w3timages/icons/tongue.gif[/img]
Old May 26, 2003 | 05:52 PM
Carlos3186's Avatar
or even better make the gear shorter bellow 100 that a way we can accelerate much fater.
Would it be possible to make the gears shorter for better acceleration
Old May 26, 2003 | 08:07 PM
DanO's Avatar
I like the gearing of the manual,
in my Lincoln Mark VIII my 3rd gear is 1.00
It is geared well for guys who like sporty driving.
Dan O
Old May 26, 2003 | 08:23 PM
Carlos3186's Avatar
i have the auto i was wondering on theauto if it would be possible to change the gear. I understand that would reduce my top speed but i realy never go over 150 so its not a big deal to be
Old May 27, 2003 | 08:57 AM
Msedanman's Avatar
O.F. Administrator
It's only a cruizing gear bro. Most of your acceleration will be done by the 4 lower gears.
I don't know how feasible it would be to change gears in the tranny. Theoretically you could raise the ratio by putting a larger (more cogs) gear in if it would fit. Trouble is 4th gear is 1/1. There's not much of a gap anyway from 5th to 4th.
I personally think the way to go would be to change out the rear end gear to a 3.5 like the 6M/T or even a 3.7.. That way you're changing all the gear ratios right from 1st to 5th. This would lower your top speed some, and raise the rpm's for the same cruizing speeds tho. = worse mpg's.
