quaife lsd
Old Nov 29, 2005 | 05:43 PM
superchargedg's Avatar
Cool quaife lsd
is it worth it to use the quaife lsd (cost) or try to get an lsd out of a junkyard z or g35.by the way do you have to drop the exhaust to drop the diff.
Old Nov 30, 2005 | 03:26 AM
ISMSOLUTIONS's Avatar
I think the quaife is pretty expensive - like about $1,400 just for the diff. Are you looking to go with new 3.91 gears or just a diff upgrade?
If your going for just a diff upgrade, what year and is your car AT or MT?
Are you looking for track or daily use and driveability?
Old Nov 30, 2005 | 09:45 AM
just a diff upgrade 03 coupe 5at,mostly street some track
Old Nov 30, 2005 | 09:56 AM
Perhaps you should just get a 6MT VLSD with the 3.5 gears from a junkyard...you'll get what you want and the step up in gears as well. When you go for anything other than the VLSD, they are truly designed for track, and streetability suffers immensely.
Try calling the guys at 350evo.com - talk to BJ or John...they'll be honest with you on a recommendation.
Old Nov 30, 2005 | 10:01 AM
thanks dude
Old Nov 30, 2005 | 05:41 PM
dklau33's Avatar
That might be correct for most cases but not all. The quaife is a torsen type lsd and has no cluth packs to engage/disengage. Therefore it is seemless in operation, does not make noise like clutch types, and thus does not compromise streetability at all. In fact, I remember reading a few reviews of people who had put in the quaife into their 350Z's and they said it felt just like the stock VLSD until you really started to push it and the Quaife did it's work. Also the ATS Carbon LSD has had favorable reviews as well regarding noise, streetability, and how it hooks up in a much smoother manner than say the Nismo LSD.
Old Nov 30, 2005 | 05:44 PM
dklau33's Avatar
My suggestion is that unless you get the stock VLSD for really cheap, don't bother with it. You would be much better going with an aftermarket VLSD performance wise for a little more money. If you are concerned about noise and streetability then get the Quaife or perhaps the ATS Carbon.
Old Dec 1, 2005 | 07:41 PM
636Racer's Avatar
OSGiken SuperLock
http://www.enonvativforce.com/lsd.htm
Old Dec 1, 2005 | 09:12 PM
b1kg35's Avatar
What years did the VLSD come in the g35 6mt? I have an 03..
Old Dec 2, 2005 | 02:53 PM
dklau33's Avatar
Only the '04+ 6MT Sedan's have the VLSD. All 6MT Coupes have the VLSD.
seagrasser
May 3, 2022 09:43 AM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
Frostbite91
Jul 27, 2015 05:25 AM
