Engine - Complete Motors Complete Motors & Motor Parts; pistons, blocks, cranks, cams etc.
FS: 2006 g35 revup part out
Old 05-25-2010 | 09:14 PM
malin's Avatar
hello i have for sale complete engine from 2006 g35 after 20000 miles engine was hydrolocked I parted out and wanna sell parts, also i have brand new nismo stainless steel clutch line 80$ shipped and rest of the stuff from ebay
engine heads
http://cgi.ebay.com/ebaymotors/ws/eB...STRK:MESELX:IT
crankshaft
timing cover
block - SOLD
thanks
Old 05-25-2010 | 09:39 PM
verilath's Avatar
Are you parting out the lower plenum? if so PM me a price
Old 05-26-2010 | 12:50 AM
banelba's Avatar
Do you have the upper arm control passenger side
Old 05-26-2010 | 01:46 PM
UCIMAplaya2's Avatar
anyone know if the timing cover from this rev-up timing cover will fit the older non-rev-up vq's?
edit: nm i can see the differences between the two
Old 05-26-2010 | 04:37 PM
stockg's Avatar
got the rev up air box. lmk. thanks
Old 05-26-2010 | 08:33 PM
malin's Avatar
i think is the same
i have also oem used oil pump 50$
6 pistons 50$
6 rods 1 is bended
all oem bolts
timing chain
nothing else
Old 05-26-2010 | 11:06 PM
Andrei's Avatar
Is there any distortion in the block cylinder sleeve where the rod was bent? If you're honest I'll give you a cookie.
Old 05-27-2010 | 09:36 PM
malin's Avatar
no the rod was bended around crankshaft
Old 05-27-2010 | 10:11 PM
Andrei's Avatar
i think is the same
No it wont fit as it is a different cast including the block and it uses different timing components and bolt patterns.
That's your cookie. ^
Old 06-01-2010 | 11:47 PM
G35CDriver's Avatar
what brand pistons are for sale?or are they stock...
Old 06-02-2010 | 03:42 PM
malin's Avatar
pistons are stock
Old 06-08-2010 | 12:28 PM
Chuck D's Avatar
You dont happen to have a passenger side Revup VTC cover do you ?
Old 06-09-2010 | 09:37 PM
malin's Avatar
bump
Old 06-09-2010 | 09:43 PM
malin's Avatar
if you need something PM i have whole engine long block
Old 06-11-2010 | 01:27 AM
DrewTheSuit's Avatar
timing cover shipped to 70448? does it include cam covers?
Quick Reply: FS: 2006 g35 revup part out
