FS: OEM Valve Covers
EDIT** i miss understod the question, no theres no gasket that you can change to solve the problem your having other then the R&D ones. Best way is to just change the covers, most likely you actually valve cover gasket is fine, but you should always just replace it
what do you mean chris? the valve covers do have the rubber gasket that is under. Not sure of the part number but just explain it at infiniti and theyll hook it up. I threw away the packaging for mine so im not sure anymore.
