DIY: Spark plug change
#241
lol too bad you couldn't figure out that it says my location at the top right corner of my post.
#242
i just did spark plug change its a pain in the A** i manages to do it under and hour but my hands are beat up lol and i alos managed to swap cylinder 4 and 6 and it was misfiring bad so i retraced my steps and violaaa. my car now and a smooth idle . next is the freaking gas gauge issue i turned it own and after i fixed the connections and it was turned off had no gas lol.
#243
Actually 1 mess up I forgot to mention was while doing the left side of the engine I accidentally disconnected the gas line and quite a bit of fuel went down into the engine compartment. I looked down to see where it had leaked onto and it was the exhaust pipe . So I grabbed a water bottle and showered the area. Then when I was done I did the ecu reset (which took a lot of tries) and then started it up and saw some smoke at first but that went away after a minute or two.
#246
#247
Lol but at least they didn't have a big gut in the way like the Americans have to deal with
#249
#250
Yea I could see how you would accidentally swap those 2 cylinders. The way it's wired makes it appear like that's where the plugs plug into I almost messed up too haha. I've read that it's a very common mistake so you're not the only one.
#251
#253
Did you get the coils connected back up properly?
Check this out - http://nissanhelp.com/diy/obd_codes/p0102.html
#255
