5/16 iso, need quick answer
Old Jun 7, 2006 | 07:50 PM
Spd2Last's Avatar
i know it says the specific #in-lb to torque all the bolts but i couldnt get a in-lb torque wrench, but i was able to get 3 useless ft-lb wrenches that caused me to break a bolt that wasnt important. what i did was torque the bolts with a 1/4 ratchet until they were nicely snug n tight, but not too tight. i should be ok right? i ran my car a bit, the sound is AMAZING, but when i rev in place, the revs go down a little low causing a bit of shake then it idles normally again. is that something i should be worried or check around for?
also, just in case that i might have torqued the bolts a lbit too tight, what can i expect and when? (sorry if the question's unclear, but for example: "u can expect for the plenum to crack if u drive too hard" or something like that)
thanx
Old Jun 8, 2006 | 11:17 AM
Spd2Last's Avatar
come on guys, nobody?
Old Jun 8, 2006 | 11:38 AM
Glex25's Avatar
Administrator
I tighten the screws by hand with a socket driver.
Then i use a socket wrench and turn it like 1/4 to finish tighten it up and that should be good enough for you.
Old Jun 8, 2006 | 05:15 PM
Infiniti514's Avatar
I don't know if all Pep Boys do this, but the one by my house rents out equipment. So I rented from them an in/lb torque wrench. Its free, as long as you bring it back. You can also add thread lock to the bolts to help keep them tightened.
suby01
Not G35 Related
May 25, 2016 03:07 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
prinny
Nov 22, 2015 11:07 PM
Jcruzg35
Sep 26, 2015 04:47 PM
