Autozone special: Oil
Old Jul 12, 2006 | 10:21 AM
boxa87's Avatar
If any of you have an autozone around go there ASAP. They have buy 5 quarts of mobil 1 oil and mobile 1 oil filter for only $30.00.
I baught 30 quarts of 5w 30 and got 6 oil filters for basicly free. So im set for the next 6 oil changes!
Old Jul 12, 2006 | 10:31 AM
Pratik's Avatar
Moderator
You can get the 5 quart jugs of 5w-30 at Walmart for $20. How did you get 30 quarts for basically free? I'm confused.
Sometimes Pepboys and Autozone has the deals for $1.99 or 2.99 for a quart.
Old Jul 12, 2006 | 10:41 AM
carlitos09's Avatar
I need to change my oil thanks for the tip
Old Jul 12, 2006 | 10:44 AM
boxa87's Avatar
you can get 5 quart jugs of 5w-30 for 20$ ?? where the hell do you live, i need to move there?! I know in florida its 5 a quart for mobil 1 synthetic......
Old Jul 12, 2006 | 11:10 AM
waijai's Avatar
i.love.gold
Yeah Walmart has the 5 quart jugs for $20.
Old Jul 12, 2006 | 11:58 AM
mwarsh1's Avatar
um you saved 5 bucks, wahts so great about that. now your oil will be sitting in your garage, for months, and get stail, your right seems like a good idea. honestly im not making fun, but you didnt get a great deal.
Old Jul 12, 2006 | 12:37 PM
boxa87's Avatar
oil doesnt go stail if its sealed buddy....and around here i did get a good deal its normally 50$ i only paid 30 so i think thats 20 i saved....maybe you should check your math
Old Jul 12, 2006 | 12:59 PM
mwarsh1's Avatar
figure all over the world 1 qt of mobil 1 is 5 dollars, y do you pay 50. and a mobile 1 oil filter is 10 bucks all over. so 5 x 5 = 25 and a ten filter is 35 so you saved 5 dollars. as i said before im not trying to insult you, but i dont see how you aved alot. maybe they over charge where you live.
Old Jul 12, 2006 | 03:27 PM
boxa87's Avatar
Probably do over charge here, but we dont have state income tax though, instead everything that you buy is taxed except food at the store. Mobil 1 is $6.15 a quart here and i need 5 quarts then its taxed as well and the oil filter i checked was 12.00. so w/e that is plus 6.5 % sales tax......
whatever i was just posting it to tell people they could save a little bit. i guess it only saves if you live in florida...
Old Jul 12, 2006 | 03:41 PM
romanwarrior's Avatar
It's $22 at Walmarts in SoCal. We're getting screwed here in Cali. That's it... I'm moving to Texas. Hahaha.
Old Jul 13, 2006 | 10:51 AM
rvalencia77's Avatar
the sythetic myth..
my g has 30 k and has been dealer serviced for its entire life..... People say that once you put reg oil in it and change to syn it is not good! any comments or feedback? I need to change me oil and am not taking it to the dealer again, bunch of a-holes workin at infiniti! thanks!
Old Jul 13, 2006 | 12:40 PM
boxa87's Avatar
i have never heard of that....everyone thread i have read online conserning oil everyone usually changes to synthetic after their first oil change....never heard it did anything bad on the engine
Old Jul 14, 2006 | 12:59 PM
sliderg35's Avatar
It is not good to start with synthetic because the initial break-in requires that some wear occur to seat the rings. Once that initial process is complete, synthetic will reduce the progress of wear inside the engine - thus extending the life of your motor. The point here is that you MUST start with normal oil for the break-in. Switching after that is prodent and recommended.
Old Jul 14, 2006 | 03:07 PM
boxa87's Avatar
thanks for the information.
Old Jul 14, 2006 | 08:13 PM
chiapet15's Avatar
I've heard this theory a lot before, and I think if it were really true, then a lot of the companies that use mobil 1 synthetics as a factory fill wouldn't be doing so. However, if it were to be true, then the engine you get in a new Corvette or new Mercedes AMG would already have thousands of miles on it from the break-in period in preparation for the synthetic oil.
And doesn't most engine wear occur at startup when the oil hasn't reached the valves and piston rings yet? I think just starting it up introduces enough wear regardless if a synthetic or dead dyno juice is being used. Because of this, I was going to consider an Amsoil pre-oiler, which bythabay installed on his sedan.
Anyone else want to chime in?
