power GAINS or power LOSS?
Old Oct 5, 2006 | 11:55 PM
YO_its_KENN's Avatar
i am looking to go with strup headers accompanied by fast intentions high flow cats along with fast intentions exhaust.
i've been reading that some N/A going this routine has had power robbed from them? i am looking to spend a lot of money on these mods and dont want to have to regret them if they end up taken power from my engine.
also. should i look into TechnoSquare ecu reflash?
i am currently running ztube w/popcharger, 5/16 spacer and UR pulleys.
Old Oct 6, 2006 | 12:10 AM
anDross's Avatar
Torque will be lost around the low part of the powerband I believe. But you'll gain more on mid and high end..
Old Oct 6, 2006 | 09:59 AM
Nightshifter's Avatar
First of all, the factory ECM, has a tolerence level for all the parameters. If things start to go outside the parameters, it tries to compensate. The bull**** of resetting the ECM doesn't work. You just didn't erase factory code and have it relearn the new mods. In time, the computer will just try to keep adjusting within the factory settings. Get a technosquare reflash would help, but that might be a back & forth thing for while. Some people, like the guy with the G35 Sedan, made the car run worse after a few days. A better choice would be to get the new S-tune Stage II kit from NISMO that will bump your car to 320 ~ 325 RWHP! Compression Ratio is now 12.3:1 all factory tuned! All the parts work together with the s-tune II ECM. No guessing, no wasting your time, no worrying about retuning your car all the time. Check it out >>> http://www.poweraxel.com/nismo/news/...6/n060001.html
yen to dollars around 7500.00 for the KIT. Looks sweet too!
Old Oct 6, 2006 | 05:09 PM
ChromiumBlue7's Avatar
does that mean its shipped from japan?
Old Oct 6, 2006 | 06:41 PM
ttrank's Avatar
Grocery getter
Ouch!!
$7500 plus install would be at least $9-10k.
For that kind of power just get a Stillen SC. You will keep your oem powerband shape but gain 30-40% easy for a lot less.
Old Oct 6, 2006 | 09:01 PM
trey.hutcheson's Avatar
I also believe those are no WHP numbers.
Old Oct 7, 2006 | 02:50 AM
techi13's Avatar
7500 is alot of money
why dont you tell him to get an M3 instead
Old Oct 7, 2006 | 05:40 PM
so if i go that route, might as well get the technosquare. is there a downside?
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Usman Ali
Oct 4, 2015 08:23 PM
thechitoguy
Oct 1, 2015 05:25 PM
vamarris
Sep 26, 2015 12:56 PM
