stillen z tube VS. oem z tube
Old Oct 6, 2006 | 11:20 AM
hotsocal's Avatar
I hope i dont open up a can of worms on this one, but im going to be getting a z tube , is the stillen better then oem or is there really no difference performance wise or sound wise..
Old Oct 6, 2006 | 11:49 AM
DaveB's Avatar
Same. I'd stick with OEM just because it will fit like OEM.
Old Oct 6, 2006 | 11:53 AM
Jeff92se's Avatar
Red Card Crew
Stillen = 50 extra hose powah! The dynos are out there. Search
j/k
Old Oct 6, 2006 | 11:59 AM
vt_maverick's Avatar
I actually read that the engine bays are slightly different between the Z and G and that the stock Z-tube has a tendency to rub a little (in the G engine bay). I think that the Stillen Z-tube has some bend in it to compensate. You may find that the Stillen tube fits better than the OEM one.
Old Oct 6, 2006 | 12:00 PM
Not to mention that the Stillen tube is cheaper...
Jeff92se's Avatar
Red Card Crew
I run the Z tube. Fits perfect. IMHO, unless you want some blingity blang a blang, it's not worth the extra $ for anything else.
Old Oct 6, 2006 | 12:12 PM
g35rcr's Avatar
the z tube has no rubbing issues as long as you mount it the same way the stock tube mounted, ive had one since 500 miles and now at 63800 miles still no rubbing
Old Oct 6, 2006 | 12:13 PM
DaveB's Avatar
My Z-tube fit like stock too. 10 minutes install. I'd much rather pay a few more bucks for a factory peice just because it's engineered right, even something as simple as an intake pipe.
Old Oct 6, 2006 | 01:19 PM
superchargedg's Avatar
+1 get oem.
Old Oct 6, 2006 | 01:42 PM
I'm about to put a Z-tube on myself so it's good to hear the misfit thing is something of a myth. It seems like a lot of people were complaining about rubbing with the AC lines in a lot of the intake threads. Maybe people were doing something wrong?
Old Oct 6, 2006 | 01:43 PM
gladiac2k1's Avatar
++1 on the OEM z-tube. Mine fits perfectly in the car!
Old Oct 6, 2006 | 02:20 PM
g35rcr's Avatar
I ended up cutting the bracket off of mine after I broke it and then with my throttle body spacer the bracket was useless unless I wanted to use their extension piece which is unneeded
Old Oct 6, 2006 | 06:43 PM
ttrank's Avatar
Grocery getter
I would get which ever one was less. The performance and fitment of both should be the same.
Old Oct 9, 2006 | 03:33 PM
Gordgee's Avatar
Administrator
Looks like the Stillen Z-Tube goes for about $60. I believe that the OEM tube is about $75 and up, so Stillen has the better deal unless you can get one from a Z owner that is getting rid of his. The going price for a used Z-tube is about $50 unless you're lucky enough to get one for less.
In Canada, the dealerships charge about $150 CDN!!!
Old Oct 10, 2006 | 06:51 PM
Skaterbasist's Avatar
Retired SuperMod
Get stillen Z Tube.
I have it and it works great.
