Dealer Wouldnt Clean My Maf
Old Oct 13, 2006 | 06:39 PM
chobble19's Avatar
They said it doesnt need to be cleaned and shoudnt told me that the air filter (if needed) only need repalcement and also told me not to use the crc cleaner how worhtless
Old Oct 13, 2006 | 06:53 PM
brian_g20's Avatar
They're probably just covering their ***. MAFs are very sensitive and expensive. I'm sure they don't want to mess with it unless there's something wrong.
Old Oct 13, 2006 | 11:39 PM
exagorazo's Avatar
So disconnect the wire attachment by squeezing the retaining clip on the bottom side of the attachment plug and pull it off. Remove the two bolts and slide out the MAF.
Then spray it with brake cleaner or starting fluid (ether). Spray from at least a few inches away so you don't damage the fine wire.
Wait until you're sure it's dry (a couple minutes) and reinstall it. The job won't take over five minutes unless you drop one of the screws and it falls down into the engine somewhere and doesn't make it all the way down to the driveway. If that happens, the project will take at least six minutes ...
Old Oct 14, 2006 | 06:10 PM
Gordgee's Avatar
Administrator
...Or like most dropped nuts and screws, what seems to be about 1 to 2 hours!
Old Oct 18, 2006 | 03:07 PM
rlwjr1's Avatar
Dealers make money selling parts, not brake clean or electrical cleaner. It's true.....
Old Oct 18, 2006 | 08:40 PM
nikkun's Avatar
they're covering thier aS$
AuAltima3.5
Audio/Video/Electronics
Sep 12, 2015 08:21 AM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
TrillO.G.35
Sep 5, 2015 02:06 AM
n2fooz
Sep 4, 2015 07:46 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
