Hitting the rev limiter
Old Oct 31, 2006 | 01:15 AM
ChiefyMan's Avatar
Alright, so, twice in the past, oh, 2 weeks or less, I've hit the rev limiter. First time, I down shifted one to many (2nd instead of 3rd) - I have the 5AT - as I was thinking I was in 5th, not 4th. A second after I got into 2nd, it hit the limiter, bouncing off about 4-5 times before the tranny would up-shift into 3rd (ugg - I HATE, absolutely HATE the 5AT lag!) Tonight, I accidentally hit it (once again, in part thanks to the lag, but also in part due to my own fault) as I was burning out, the tires didn't catch as quickly as I thought they would (hey, it's cold out... but I shoulda known better) and the rev limiter came up a little bit quicker then I was expecting, bounced 3 times before it would go into 2nd gear (tires were still spinning until 2nd gear came up)
Question is, do I need to worry about any possible damage w/ those two incidents, or is the VQ a strong enough engine that in can handle a few bounces every once in a while as long as it's not to often? If I need to worry, what should I look at to find if any damage has been done?
Thanks!
Old Oct 31, 2006 | 09:42 AM
Calvin's Avatar
Overglorified Altima
the rev limiter is there for a reason. to protect you from really fvcking anything up. you should be fine.
Old Oct 31, 2006 | 09:58 AM
GreenGoblin's Avatar
The goblin resurrection
yup that is what it does limits so that you dont destroy your motor
Old Oct 31, 2006 | 01:31 PM
Canadian's Avatar
Canada, eh?
Its 1030am and I've probably hit it 5 times this morning since 6AM. You will be fine
Old Oct 31, 2006 | 02:13 PM
JOKER's Avatar
CLUB MODERATOR
ever tried to let the foot off the gas pedal. I heard it helps.
Old Oct 31, 2006 | 02:19 PM
Canadian's Avatar
Canada, eh?
^^But then driving isn't fun, now is it?
Lighten up a bit bud, it was a joke.
...or was it?
KruZZe
Feb 27, 2023 05:04 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
mbe32
Nov 13, 2015 11:09 PM
vamarris
Sep 26, 2015 12:56 PM
