Is an engine flush worth it?
Old Nov 26, 2006 | 08:03 PM
mswc's Avatar
Crucial dude
I took my car to get the oil changed recently (at 76000 miles) and the techs recommended I should get my engine flushed. Now when an engine is flushed, it's to get the sludge out right? Is this worthwhile to do on the G35? I've read some pros and some cons other places, but I can't seem to dig anything up on G35driver about anyone having their engine flushed. I normally use synthetic oil, but for the past few changes I've been using regular (and high mileage).
Old Nov 26, 2006 | 08:08 PM
k_hojnacki's Avatar
I suggest against it and most likely you do not need it. If you do flush you have the possibility of dislogging some sludge that may end up causing it to plug an oil passage. If you have been using synthetic, the chance of sludge is minimal anyway. Why take a chance. JMHO
Old Nov 26, 2006 | 08:54 PM
Msedanman's Avatar
O.F. Administrator
+1.....no flush. -- but don't go long intervals between oil changes. Some of these oils promise longer mileages like 10-15k miles but I don't believe in that.
Whatever oil you use, go by the normal change schedule....
C.
Old Nov 26, 2006 | 09:06 PM
GreenGoblin's Avatar
The goblin resurrection
^ agreeed I would never leave oil in that long just every 3 to 4k have it changed
Old Nov 27, 2006 | 09:23 AM
Callaway's Avatar
C.
I would never think about going 10-15K miles between oil changes, but I do go 5-6K miles which shouldn't be a problem with Mobil 1.
Old Nov 27, 2006 | 10:07 AM
durtee_south's Avatar
Mobil 1 and all synthetics are good...IMO, nothing competes with royal purple oil
Old Sep 9, 2007 | 12:27 PM
05GCOUPE6MT's Avatar
agree
Old Sep 9, 2007 | 06:57 PM
BadBoy06's Avatar
not worth it
Old Sep 9, 2007 | 07:45 PM
V35 Skyline GT's Avatar
6MT Coupe
Nah...I wouldn't do it, for the many reasons already mentioned why.
Old Sep 9, 2007 | 11:35 PM
fherjohn's Avatar
redline>royal purple
but, ENEOS is top of the line. i'm using 0w-50 and my engine revs alot quicker. felt the diffrence right away. for those who don't know, eneos is the number 1 oil in japan.
Old Sep 10, 2007 | 02:03 AM
partyman66's Avatar
Lots of oils not only compare to Royal Purple, but are much better than it. Royal Purple is the bottom rung of the "true" synthetic oils if you look at the specs for it and compare it against those of the better true synthetics(Pour Point, Flash Point, etc).
Better oils are Motul, German Castrol, Amsoil and Redline. I've never really looked into this ENEOS oil that the other guy mentioned, so I have no comment on it.
2 few friends of mine used to use Royal Purple for race applications on their street-legal cars(Autocross, small 1/3 mile oval track racing, and a few drag-strip runs) but they both stopped when they started having excessive oil consumption issues with the Royal Purple that they never had with other oils. One of them actually had to replace his motor because he did damage when he burned through most of the oil in the sump over the course of about 1000 hard miles(several track events) that he foolishly didn't check his oil level during... and it was on his first oil change after switching over to Royal Purple from some other oil(not sure exactly what other oil he was using beforehand).
My personal recommendation is to go with German Castrol if you can find it at your local Auto Zone. It's usually about $6.10 per quart and is fantastic stuff. German Castrol is 100% different than regular Castrol Syntec(GC only comes in 0W30, but is actually a very thick oil for that rating), so if you want to find out how to identify true German Castrol go search on google for a picture of the bottle or look on the back of the bottle for the "Made in Germany" tag. The bottle will also probably say "European Formula" in a yellow section on the front of the bottle.. although just because it says European Formula, doesn't mean it's German Castrol. If it says "made in the United States" or something like that, it's not German Castrol. It should also have a green starburst on the front label... but the true indication is the presence of the "Made in Germany" on the back label that I mentioned.
Old Sep 10, 2007 | 04:48 PM
Jtrain's Avatar
I change my oil after 1,000 miles because my car didn't seem to be responding well. Especially when your boosted, its best just not to take chances.
Old Sep 10, 2007 | 04:52 PM
Nismo G's Avatar
Honestly i would just go fill half a tank up of some 100 octane and floor the car around here and there. That should burn any sludge out of the engine.
-Sean
Old Sep 10, 2007 | 04:54 PM
Jeff92se's Avatar
Red Card Crew
How would any "sludge" in the engine be affected by using 100 octane and driving crazy?
-Sean
Old Sep 10, 2007 | 04:55 PM
Nismo G's Avatar
hmmm, thats odd. I have been running royal purple 10w30 for about 20K miles now and haven't had any problems. Before that i had mobil 1 5w-30 for the entire life of the car. Royal purple is known strictly for a racing oil, but if what you say is true .
I have been wanted to try the greddy racing oils...but you have to order it.
-Sean
