Utec Users????
Old Nov 29, 2006 | 01:17 AM
crza81's Avatar
Utec Users????
Is anyone using the utec and what are you using to monitor the a/f ?? i dont like the turboxs a/f tuner , it is too large.. also how user friendly is it to tune ??? My next mod needs to be some kind of ecu reflash or piggy
Old Nov 30, 2006 | 12:21 PM
KPierson's Avatar
I'm using the AEM wideband. For logging I'm running the wideband to my laptop via 9 pin serial port and I'm logging the UTEC with USB. I'm using the MPS UTEC logging software to log both values simutaniously.
Hopefully, in the near future, I'll have a better option, but this works for now.
Old Nov 30, 2006 | 12:39 PM
crza81's Avatar
Thanx for ur help. does the software allow you to log the a/f values on the same screen as the utec? and is it the aem uego??
Old Nov 30, 2006 | 03:21 PM
KPierson's Avatar
Yes, it does. I actually have mine set up to display on my Navi screen.
The only drawback is that it requires a computer for processing.
Old Dec 4, 2006 | 02:23 AM
Triji's Avatar
Ok huh??.....
The Utec does not allow you to datalog AF ratios???? What does it datalog then? AF is like the most important thing to datalog IMO.....
Old Dec 4, 2006 | 06:11 AM
KPierson's Avatar
The UTEC doesn't have any user inputs on it. You can log TurboXS widebands, but there are a lot of people who had A/F guages before UTECs. Had I bought my UTEC first I might have just went with the TurboXS wideband, but since I already had the AEM installed I'm going to use it.
Old Dec 4, 2006 | 07:47 AM
Audible Mayhem's Avatar
exactly, the utec will datalog your AF ratio perfectly if you buy turboxs wideband. kevin has figured out a way of datalogging the AF ratio using any wideband onto the same screen...
if you dont have a wideband already, i would get the turboxs one, they all are going to cost you 300-400 for a really good one, so why not just skip out having to cut up and make your own serial cable etc...
i understand if you already have a wideband and dont want to purchase another one
Old Dec 4, 2006 | 11:07 AM
Triji's Avatar
I have the Zeitronix which has wideband... If I get the UTEC is there anyway to innerface the two? I got some research to do.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
Blue Dream
Dec 5, 2015 10:56 AM
w4kj4k
Oct 2, 2015 07:57 PM
