Group Buy-SAMCO Silicon Coolant Hoses
Re: SAMCO Update
Uhhh... the radiator hoses will have some pressure running thru them.. I do not recommend zip ties. You should really consider getting worm drive clamps until while you look for alternatives.
Cheers,
Ted
'03.5 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click for MODS or Vote at Online Showoff
Cheers,
Ted
Re: SAMCO Update
The 'worm drive' hose clamps from VW are excellent quality, and have a lining under the band that prevents them from 'chewing up' the hoses. Worth a consideration if you want higher quality than the standard hose clamps from the hardware store.
<font color=blue>[i]GroundingGear™ Equipped </font color=blue>
Re: SAMCO Update
I thought I could get a better bite on the hose with a zip tie than the crappy factory clamps.
Russ
Black 6MT Coupe
Jax, FL
G35Driver.com Business Cards
Russ
Black 6MT Coupe
Jax, FL
Re: SAMCO Update
Has anyone tried the Pi-Thon fittings with the Samco hoses??
I hear they are a real PITA to put on because of the thickness of the hose...Any pics of this combo would be greatly appreciated!!!
Re: SAMCO Update
Has anyone tried putting on the entire set with the OEM clamps? Which work / don't work?
Re: SAMCO Update
got my kit and installed it with the nismo LT thermo
excellent fitment, cept the overflow bottle tube (smaller dia) wasnt form-fitted....
oh well, another base covered......
Re: SAMCO Update
What did you use for fittings/connectors? Factory?
Russ
Black 6MT Coupe
Jax, FL
Russ
Black 6MT Coupe
Jax, FL
Re: SAMCO Update
i draine the rad. as i was installing the nismo LT thermo ast the same time....
the oem pinch clips will work for the main hose (and sev. others) but the smaller ones need bigger clips, as these are noticably thicker than the oem hoses......
Re: SAMCO Update
I got my red hoses. Thanks Ted!
Black on Black 5AT Coupe, Navi
Falken Koblenz 19x8.5 F 19x9.5 R
Falken FK-451 245/35 F 285/35 R
HKS Legamax Exhaust
350Z Duct
Stillen Hi Flow
7 Wire Hypergrounding Kit
HKS Legamax Exhaust
350Z Duct
Stillen Hi Flow
Re: SAMCO Update
the over flow on the OEM is not form fitted either.
I had also cut my over flow (which we were warned about) down about on to two inches. The OEM clamp work on this one, but DANG was it tight!
I also got the OEM clamps to work on the larger radiator hoses, but it was SO TIGHT and a PITA, that I opted to use the worm drive clamps.
-t
-t
Re: SAMCO Update
Be careful using standard worm clamps. They can eat into the hose and chew it up over time. Call around and get some 'silicon-safe' hose clamps. The band has a liner that protects the hoses. I think the ones from VW are like this.
