Light above the temp gauge?
Old Nov 15, 2003 | 04:01 PM
SilverG35C's Avatar
Has an exclamation mark on it...tried to look in the manual and nothing really resembles it. Anyone have a clue what it is? It popped on last night and my car beeped like mad.
Jason Siu
http://www.g35coupe.net
Old Nov 15, 2003 | 09:06 PM
RaySur350GT's Avatar
Re: Light above the temp gauge?
More likely it's a warning that you were overheating and trying to get your attention.
- Don't argue with idiots. They will bring you down to their level and beat you with experience.=P-
Old Nov 15, 2003 | 10:14 PM
3point5SE_Auto's Avatar
there are the following lights on the combo meter: abs, srs, vdc, slip, oil, cruise, cruise set, high beam, windshield washer, battery, turn indicators, seat belt, trunk/door, brake, ("!"), AT check, low fuel, MIL light, and coolant temperature.
sounds like that is the coolant temp.
BTW, the esm says if there is a malfunction to change the coolant and the engine oil. IF it turns out to be a problem under warranty, make sure the dealer does the above changes per the ESM
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Custom Catback, Custom Intake Tube, HyperGround Kit
Old Nov 15, 2003 | 11:00 PM
jdove's Avatar
It means low tire pressure.
Old Nov 16, 2003 | 07:56 PM
Msedanman's Avatar
O.F. Administrator
Must be a 2k4. No light on my 2k3.
GSM
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Old Nov 17, 2003 | 04:12 PM
AirSplat's Avatar
Yeah, it's the low tire pressure indicator. That thing lighted up the first time I drove it home! I seems to light up when driving long distances. I just got back from Vegas and it was lit the entire way. and I even stopped to measure the pressure it was at 40 PSI! That's not low at all!!! There's something wrong with it! I remember seeing some posts about it. But I'm looking for it right now as we speak, becuase it was annoying when I was driving.
'04 G35 6MT Ivory Pearl
Borla Headers/Dual Cat-Back Exhaust
AirSplat.com for AirSoft Guns!
Old Nov 17, 2003 | 05:30 PM
jdove's Avatar
Yeh the tire psi light was added in 2004. The first time it came on for me , it beeped a few time and startled the crap out of me, took a minute or two , staring at the little "tire cross-section" symbol to figure out it was tire psi. I must admit its a little lame on a "luxo" class car, not even getting info as to which tire is low? and what psi. The Z does provide this info, strange the G does not.
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
Kng0fHrts
Sep 15, 2015 05:40 PM
jcardodeucedos
Aug 27, 2015 06:28 PM
