Plenum spacer
Old Jan 9, 2007 | 03:59 PM
infinitialex's Avatar
guys do u have to drain the coolant to install plenum spacer?
Old Jan 9, 2007 | 04:00 PM
Jeff92se's Avatar
Red Card Crew
Exactly what makes you think that would be necessary?
Old Jan 9, 2007 | 04:02 PM
Well i got my skunk2 plenum and on the instructions its says to drain the coolant,,so im all confused here
Old Jan 9, 2007 | 04:13 PM
SO do I need to drain it or not????
Old Jan 9, 2007 | 06:59 PM
i need to know ...
Old Jan 9, 2007 | 11:31 PM
Joshua's Avatar
err no
Old Jan 10, 2007 | 01:39 AM
estiel's Avatar
can't say for the skunk2, but you definitely don't need to drain the coolant to install the motordyne spacer.
and you definitely don't need to drain the coolant when installing the iso-thermal components either.
if you're installing a coolant control valve (to open or close coolant hose to plenum) then you'll get some coolant spillage when you remove that hose, that's all, just wipe it away when you're done. hahaha. just like you would with your girlfriend.
Old Jan 10, 2007 | 05:50 PM
Earl's Avatar
You don't need to drain the coolant.
Have you installed your skunk spacer yet? If not please lay and align a factory plenum gasket on top of it. Then take a picture of the back center area and post it so we can see how well the two match up.
Thanks,
Earl
Old Jan 11, 2007 | 01:41 PM
Thanks,
Earl
I have not installed it yet,,kinda cold outside and I want to do this thign myself...
Good to know that dont have to drain the coolant. I cant figure out why its says in their instructions to do it.
Either way,, i will take pictures when I put this thing on.
Old Jan 11, 2007 | 06:36 PM
Joshua's Avatar
ill be doing it saturday after i get loaded on beer, ill post pics if i remember sunday
Old Jan 12, 2007 | 12:02 AM
Augy's Avatar
No draining...why the heck would it say it to drain...hmmm...
Old Jan 12, 2007 | 12:05 AM
BLKed OUT G's Avatar
HAS ANYONE JUST BEEN LAZY AND HAD SOMEONE ELSE INSTALL THERE SPACERS
Old Jan 12, 2007 | 01:03 PM
estiel's Avatar
if you're gonna pay to have someone else do it, it should be the dealer - no worries on the warranty when you take your car in for service.
Old Jan 12, 2007 | 01:18 PM
Too bad i cant use the stock cover. Anyone has come up with a way to use a stock engine cover with 5/8 spacer?
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
w4kj4k
Oct 2, 2015 07:57 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
