Any modification for better gas milage ?
Old Jan 7, 2007 | 04:36 PM
xterminal01's Avatar
Does anyone know of anything that will improve gas milage, according to some people cat-backs/intake improve up to 2-3 mpg .. any experiance on this??
Thanks in advance
Old Jan 7, 2007 | 06:22 PM
Calvin's Avatar
Overglorified Altima
no
and mods are likely to decrease mpg because youre more likely to driver harder with any mods
Old Jan 7, 2007 | 06:34 PM
Any comments on this http://www.autoanything.com/savegas/
Old Jan 7, 2007 | 06:35 PM
akachi's Avatar
i think spacers increases gas mileage
Old Jan 8, 2007 | 01:36 AM
jjpark712's Avatar
its all depends how you drive the car....
Old Jan 8, 2007 | 02:57 AM
Meatshackle's Avatar
Deep Sea Moderator
Put a spacer on the between the gas pedal and the floor so you can't go WOT.
Old Jan 8, 2007 | 10:21 AM
Q45tech's Avatar
Since the O2 system tries to maintain a 14.7 AF ratio to optimize CATS......the only way to improve MPG is to reduce the air flow into engine.......either by keeping throttle closed or using the lowest rpm possible.
Buying the highest BTU per gallon gasoline is an often overlooked factor, as ethanolized gasoline will always reduce MPG by 3% minimum [usually closer to 5% because it fools O2 system into calling for a richer mixture due to the extra oxygen already in the ethanol].
Old Jan 8, 2007 | 01:42 PM
solidskyline's Avatar
thanks. do you know this as a fact or are you approximating on the 5%?
Old Jan 8, 2007 | 04:13 PM
g35rcr's Avatar
its a fact
Old Jan 9, 2007 | 11:49 AM
Q45tech's Avatar
Calculate/measure the exact volume of oxygen [in ethanol] in the fuel to calculate the exact amount of O2 error.
Calculate/measure the ethanolized BTU per gallon vs non ethanolized to get the % of lower power output.
Modern post 2002 wideband O2 are very accurate compared to 1996-2001 heated narrow band just switching units.
Gasoline varies day by day in refinery output and degrades from refinery specs every mile thru the pipe line and thru local storage and transport to service stations.
ATL is 4 days thru the pipeline from refineries and usually another 3-5 days until it's in my tank 7-9 days old at best.
Gasoline made for ethanol blending varies significantly in exact composition since the ratios of the 250+ chemical components are hard to blend exactly batch to batch. The computers only sample about 10 [5%] of components.
Old Jan 10, 2007 | 10:43 PM
^^ thanks guys. helpful.
Old Jan 11, 2007 | 04:12 AM
2slo2bfurious's Avatar
Lol, best answer!!
Otherwise, just lay off the gas and shift early.....
Old Jan 11, 2007 | 03:11 PM
MyLilBlkG's Avatar
i second that...i think i'll take on your advice
Old Jan 13, 2007 | 11:43 AM
supra2k's Avatar
a lighter foot maybe?
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
Hogbone
Sep 28, 2015 06:44 PM
