G35 coupe + regular gas... knock sensor help !
Old Jan 17, 2007 | 05:54 PM
Potty_Pants's Avatar
hi guys,
i know this has been posted somewhere before
anyways i just got a full tank 17.3G of regular in my coupe.
any concerns for wear or gunk ?
does the knock sensor work well ?
any recommendations ?
thanks
ppp
GRRR WAWA, asst mgr blew me off and said they guarentee their gas... im like yeah but do you guarentee putting regular in a premium only car... uh.
Old Jan 17, 2007 | 06:40 PM
636Racer's Avatar
Just get in some octane booster in and call it good.
Old Jan 18, 2007 | 09:06 AM
Q45tech's Avatar
Over the counter octane boosters [those that do anything at all] contain manganese that fouls the plugs and adds deposits to combustion chamber.
You would need 2-3 gallons of the OB to accomplish the 6 rise.
The points the OB refers to are 0.1 units not 1.0 units
Old Jan 18, 2007 | 09:57 AM
Thanks Q45tech,
I didnt want to make the problem worse by going against the owners manual ... states no aftermarket fuel additives.
Havent heard back from wawa yet, just going to drive it under 3k, no rabbit starts and fill up with premium when i use 5 gal or so.
ppp
Old Jan 18, 2007 | 07:29 PM
636Racer's Avatar
true. I forgot about that.
next best thing is using 4:1 - Gas:Xylene. For every gallon of xyline, you need 1oz. of Marvel Mystery oil.
it's just some homebrewing stuff I learned when I had my t-type. Not as good as race gas, but enough to get by.
reference:
http://www.gnttype.org/techarea/misc/octanebooster.html
formula 2
Old Jan 20, 2007 | 07:08 PM
Godfather's Avatar
^^i luv ur avtar
Old Jan 22, 2007 | 07:42 AM
update:
usually avg 16.5-17mpg (as per nav screen)
been at 15.5mpg during the winter gas
with regular im running 11mpg.
glad there is no pinging, just want this low grade outta my tank !
ppp
Old Jan 22, 2007 | 08:26 AM
Q45tech's Avatar
The major difference between regular and premium is the amount of detergent additives found in premium..........octane is a minor consideration except that a the KS system retards the base timing the engine efficiency goes way down and mpg drop progressively. Peak Power is reduced by 2-3% with regular.
20 cents per gallon premium is a tiny price to pay to get the extra detergent additives with out resorting to Techron [$7 per tankful] or BG44k at $15 which is enough to treat 3-4 tankfuls.
chinee
Jun 10, 2024 07:48 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
igking
Jul 19, 2015 01:12 AM
Thaaa_king
Jul 18, 2015 05:56 PM
