Spin my tires in 3rd
Old Nov 23, 2003 | 02:35 AM
joecross98's Avatar
For my style of driving, my goal is to be able to spin my tires in 3rd at ~4000rpm.
I'm not sure what it takes to get there (new exhaust or TT kit?), so I'm looking for some advice.
What kind of setup would it take to spin my tires in 3rd?
Old Nov 23, 2003 | 03:31 AM
gdupg35's Avatar
Re: Spin my tires in 3rd
Nitrous, TT, Or Supercharger will get you there. How about some bald tires or spill a bit of oil on the road?
Old Nov 23, 2003 | 12:36 PM
joecross98's Avatar
I could drive my '67 VW bus to work first and spin out on the oil slick that streams behind it...
I've been looking at TT and SC setups, but I can't believe it's as easy as shelling out $8K for the engine alone. With the extra power, I expect to need some tranny work, an ECU upgrade, better tires, etc. All said and done, a TT or SC is probably more int he neighborhood of $10K+.
Is that a fair assessment? If so, I'm wondeirng if there is a cheaper route to spinning my tires in 3rd?!?
Old Nov 23, 2003 | 12:51 PM
G35Lin's Avatar
Multi-Spoked Mod
nos! thats about it
Old Nov 23, 2003 | 12:59 PM
ryoken's Avatar
Actually, if your goal is to spin your tires, you want worse tires, not better tires. Better tires will give you better traction, stick to the ground, and launch the car forward. You want the cheapest all-season non-speed-rated economy passenger tire you can find. Then you might even spin it in 5th with a stock engine. [img]/w3timages/icons/smile.gif[/img]
Old Nov 23, 2003 | 01:13 PM
Shader7's Avatar
Exactly what style of driving do you have?
03.5 Coupe - Black/Willow, 6MT, Premium, Navi, Aero, Sat
Old Nov 23, 2003 | 02:32 PM
typhoonro's Avatar
Yeah, what kind of driving do you do that you would want wheel spin in 3rd gear? Is it to show off? Cause, I can't see what use it would be in real world driving or even in a drag race.
Old Nov 24, 2003 | 03:40 AM
humanRESEARCH's Avatar
Ummm...When is it ever good to display a loss of traction? I recommend getting two spare tires (possibly off a couple of Sentras, just to be trick), installing them out back, and driving around looking for puddles...
"All the Power in the World resides in the Eyes..."
Old Nov 24, 2003 | 06:49 AM
Scoop's Avatar
Driving on ICE will let you spin wheels in all 6 gears. Try it you'll like it [img]/w3timages/icons/smile.gif[/img][img]/w3timages/icons/wink.gif[/img]
Scoop
Old Nov 24, 2003 | 11:25 AM
ryoken's Avatar
I just had a thought.. get two compact spare donuts and put them on your rear wheels. That'll do the trick.
Old Nov 24, 2003 | 11:29 AM
Shader7's Avatar
My style of driving is to be able to get enough air over a speedbump to do a complete barrel-roll in the Safeway parking lot.
Scoop, your fuel filler lid is open, i.e., "The cucumber has left the salad!"
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
Frostbite91
Aug 20, 2015 07:20 PM
itschuckster
Jul 25, 2015 08:07 AM
Lsantana757
Jul 20, 2015 09:08 AM
