Q: Temperature Display: Celsius vs Fahrenheit
Old Nov 24, 2003 | 09:41 PM
bsoo's Avatar
Does anyone know how to switch between Celsius and Fahrenheit in the temperature display (ambient and cabin)?
I recently drove in below freezing temperature and I think it kinda sucks that our car doesn't warn us about that. Availability of a Celsius display would have helped.
http://www.imagestation.com/member/?name=bsoo
Old Nov 24, 2003 | 10:56 PM
Msedanman's Avatar
O.F. Administrator
Re: Q: Temperature Display: Celsius vs Fahrenheit
bsoo, I haven't had time to get into it yet but you can engage a diagnostic mode by turning on the ignition and within 10 seconds, push the OFF button of the HAVC controls. You will then see all the upper stack display light up including celcius and fahranheit options.
I don't think you can mess things up so play around with it. You may find a temp display choice.
The ESM explains that the battery voltage must be at least 12 volts, and that starting the engine to perform this diagnostic is recommended. Have fun.
G/L
GSM
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Old Nov 25, 2003 | 02:28 AM
bsoo's Avatar
I looked at the diagnostic section of ESM (thanks for pointing it out) but there was no information on how to switch between C & F (though both units would light up).
Any further help would be appreciated.
Old Nov 27, 2003 | 06:58 AM
lilteyang's Avatar
could you clarify the procedure for the diagnostic mode?
I repeatedly try to turn on my engine and press the off button...
nothing happened...
Old Nov 27, 2003 | 07:22 AM
bsoo's Avatar
You have to press and hold the Off button for 5 seconds. By the way if you don't have the ESM manual to follow I suggest you not to mess with it coz it can change certain settings.
Old Nov 27, 2003 | 05:09 PM
Msedanman's Avatar
O.F. Administrator
bsoo: Not sure on the diagnostic mode yet. When I get some time, I'll 'play' with it some more and post results.
lilteyang: Just turn on the engine and then push (and hold) the off button within 10 seconds of starting. After a few seconds of holding the off button, it engages the diag. mode and you'll see the corresponding display on the upper pod.
GSM
GSM
Old Jul 14, 2009 | 01:55 PM
GiLLG35's Avatar
I am new to the forums and searching to find how to switch Fahrenheit to Celsius in a 05 G coupe as I may purchase a 05 G coupe that is american. I found this thread but also found the wire harness one, and I was wondering if this method worked or would i need to do the wire spiltting one? thanks
AbyteZero
Mar 25, 2016 06:30 PM
Usman Ali
Sep 22, 2015 06:59 AM
mattdg35
Sep 14, 2015 11:28 AM
j_mullet
Aug 26, 2015 10:49 PM
Felipe Gonzalez
Aug 16, 2015 10:02 AM
