motordyne 5/16 spacer
Old Mar 27, 2007 | 09:54 PM
OCG35's Avatar
Originally Posted by ttrank
I have had two motordyne ones and the gasket was not adhered to it. That may be a more recent change.
You can re-use it.
I believe it's new... I'm not positive and Tony would have to confirm, but from what I’ve read elsewhere it seems current production has the gasket adhered.
Old Mar 28, 2007 | 12:22 AM
psedog's Avatar
Back in SD**
I've been taught to always change the gaskets whenever you open up any part of the engine or tranny. If not you can have leaks. It's always safe to just replace them and divert any issues that might come.
Old Mar 28, 2007 | 01:16 AM
gramdacious's Avatar
The plenum gasket is pretty durable and the Motordyne instrusctions said to re-use it.
Old Mar 28, 2007 | 01:40 AM
OCG35's Avatar
mine has been on & off twice - same gasket... your fine.
Old Mar 29, 2007 | 12:05 AM
Hydrazine's Avatar
Hi guys,
Yes, there is a recently new gasket design. The new gaskets are much thicker and more compliant than the previous gaskets and do a much better job of sealing. Even on a slightly bent or scratched plenum.
Not that you want a slightly bent or scratched plenum, but it will accomodate it.
The new thicker gaskets are bonded to the spacer so that the spacer itself is not effectively one thick gasket with half the sealing surfaces.
Its also fully reusable.
Old Mar 29, 2007 | 12:50 AM
OCG35's Avatar
Originally Posted by Hydrazine
Hi guys,
Is the new "thicker" gasket available to purchase separately? Or is it adhered to the new spacers only?... The reason I ask is next time I take the plenum off I might as well add the newer gasket if it's available (or worth it).
Old Mar 29, 2007 | 01:32 AM
Hydrazine's Avatar
New spacers only.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
w4kj4k
Oct 2, 2015 07:57 PM
