motordyne 5/16 spacer
Old Mar 27, 2007 | 05:04 PM
dunglan7's Avatar
Hi guy. Just bought a 5/16 spacer from a member here. Can I install the spacer without any of the hardware (gasket, bolts, washer)?
Old Mar 27, 2007 | 05:21 PM
ttrank's Avatar
Grocery getter
Nope you need all the longer bolts, plastic spacers and gasket. They all should have came with the spacer.
Old Mar 27, 2007 | 05:23 PM
gramdacious's Avatar
No. I just did the same thing. Bought a 1/2" spacer with no hardware. You DEFINALTEY cannot install it with out the kit. The kit by itself was $35 shipped from Motordyne. You'll need plastic plenum spacers and a whole list of different sized bolts along with washers that only come in the kit. Email them with your request and they will get it out to you in a few days. Once I put mine on; it was well worth it.
Old Mar 27, 2007 | 05:28 PM
dunglan7's Avatar
Did you get the gasket also?
ttrank's Avatar
Grocery getter
Don't forget the gasket too.
Old Mar 27, 2007 | 05:34 PM
dunglan7's Avatar
Someone for 350z said the gasket is on there already. Is it true because I didn't see one.
Old Mar 27, 2007 | 06:18 PM
bobshuai's Avatar
post some pictures with what you have so far. So we can see it and help you at the same time.
Old Mar 27, 2007 | 06:19 PM
Mine had a gasket already adheared. Yours isn't?
Old Mar 27, 2007 | 06:21 PM
psedog's Avatar
Back in SD**
I think his is used, so the old gasket would be worthless anyway.
Old Mar 27, 2007 | 06:26 PM
Why would the old gasket be useless?
Old Mar 27, 2007 | 06:32 PM
dunglan7's Avatar
Hey everyone the gasket is adhered to the spacer. On Motordyne website it shows that it is separated. But everything looks good, they just forgot to include the bolts and white spacers. Thanks for the help.
Old Mar 27, 2007 | 06:46 PM
Eric@TCGMiami's Avatar
call Tony @ Motordyne
http://motordyneengineering.com/contactus.asp
He can help you out, you can get some liquid gasket maker if you dont have a stock gasket or a gasket on the spacer, if its used I recommend you spread a thin smooth bead on the old gasket to make a proper seal.
Tony can help you with the proper bolts and spacers, YOU NEED THE SPACERS if not you may crack the upper plenum.
Old Mar 27, 2007 | 07:05 PM
ttrank's Avatar
Grocery getter
I have had two motordyne ones and the gasket was not adhered to it. That may be a more recent change.
You can re-use it.
Old Mar 27, 2007 | 07:06 PM
ttrank's Avatar
Grocery getter
No it's fine, I have taken mine off plenty of times.
Old Mar 27, 2007 | 08:35 PM
Yeah. mine came already adheared and it looked like there was no way you could remove it even if you wanted to. Just make sure to torque the plenum bolts properly. I thought I was good until I turned the key and heard a terrible shriek when I gave it some gas. It was a small leak, I found a couple of bolts that needed to be tighter and it was all good.
