Twin Turbo in a 5AT and a 6MT
Old May 21, 2007 | 11:00 PM
Lvtran8's Avatar
Question Twin Turbo in a 5AT and a 6MT
If a 5AT and a 6MT G35 Coupe both have the exact same options and specifications with Twin Turbo, how much HP loss would the 5AT have and what other losses would the 5AT have?
Old May 22, 2007 | 02:10 AM
ttrank's Avatar
Grocery getter
There is a couple more % loss from the 5AT. With a TT kit they are not far off from each other.
Old May 22, 2007 | 09:22 PM
Lvtran8's Avatar
So generally, in specific numbers for HP loss, how much would the AT lose?
and no doubt the MT would win in a 1/4 mile, but to make the AT even with the MT how much added money would u have to spend, and on what would make that happen
Old May 22, 2007 | 10:31 PM
Cobra-2-G's Avatar
Manuals are generally 10-20% range in loss
Autos can be 15-30% range in loss.
I am not too familiar with the auto setup in the G, but...
I would say a valve body upgrade, better torque converter and rear end gears for the auto.
Old May 22, 2007 | 10:33 PM
Cobra-2-G's Avatar
Not necessarily true. A good auto setup will win everytime b/c of consistent shifting. Most drag cars are autos.
Old May 22, 2007 | 10:43 PM
BadBoy06's Avatar
have to agree^^^^with that
Old May 28, 2007 | 12:47 PM
ISMSOLUTIONS's Avatar
The auto SHOULD win.
1 - more traction off the line
2 - Faster shifting providing around .2 faster for the 1/4
The valve body would help to strengthen the trans, and shift even faster. The torque converter would make it more like an MT, thus loosing it's traction off the line advantage, however it would get to boost faster, hence the loss of traction.
Now, with your initial question, I would also assume, that if they had the exact same options, then you would add some weight to the MT to accommodate for the weight of the transmission in the AT, and redo the differential gears to match the MT's, as they are shorter gears. If that is not done, then it would be hard to do this comparison.
Rick
Old May 28, 2007 | 01:03 PM
Jeff92se's Avatar
Red Card Crew
I agree with everything said. Plus the auto can brake boost at the line while the manual cannot. With a VB and maybe a torque convertor, it should launch like crazy? Imagine already being in boost when you launch.
Old May 28, 2007 | 04:35 PM
light's Avatar
i heard auto tranny breaks easier then the manual one
Old May 28, 2007 | 05:49 PM
There is a greater chance of breaking anything going Turbo as opposed to an SC.
All turbo power comes on a one time, v. the SC which is linear.
Rick
g.spot
May 9, 2016 10:54 PM
Blue Dream
Dec 5, 2015 10:56 AM
RWDguy4238
Sep 30, 2015 12:13 AM
