Spacer Help
Old Jun 14, 2007 | 03:09 PM
fastGkid's Avatar
Spacer Help
before anyone says anything i have searched and havn't found what i'm looking for.
I just recently installed the MD 5/16 spacer and the idle is low around 700 compared to my idle before i had the spacer which was 1200. the idle is smooth not rough or choppy and is a constant idle of around 700.
Is this normal??
Old Jun 14, 2007 | 03:16 PM
fastGkid's Avatar
anyone?
Old Jun 15, 2007 | 11:29 AM
G35fromPA's Avatar
My idle has always been around 700 rpm, certainly nowhere near 1200 rpm. you must have had a vacuum leak somewhere. Try the ECU/drive by wire reset procedure, and then check for vac leak.
Old Jun 15, 2007 | 02:17 PM
Hydrazine's Avatar
700 is the spec tolerance range for idle.
1100 RPM is only for warm up.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
