Idle "sputtering"
Old Jan 29, 2004 | 03:35 PM
jdove's Avatar
Idle "sputtering"
Just wondering if this is common on the G35C.
I''e got 3.5k miles on my '04 G35C 2004 and have noted since the day one that when warm , idling ,A/C off , low idle that a occassional "sputter/pop" can noted , especially if listening at the tail pipe. Now that I have installed a Borla TD the sputter is more noticeable due to the extra Bass. I'm wondering if anyone else has noted this, and if it is common with this model. If not common, I am expecting a MAF or O2 sensor issue, however no MIL code is pushed. I will involve the dealer, just want to be prepared. I would have expected a car of this vintage to idle butter smooth.
Thanx
Old Jan 29, 2004 | 06:06 PM
moses's Avatar
Re: Idle "sputtering"
If your talking about the very mild occasional hiccup at idle, I think its normal. Grounding kit may help slightly.
Old Jan 29, 2004 | 06:49 PM
Gordgee's Avatar
Administrator
Don't add a Hyper-Ground kit to try to cure a problem. Make sure everything is running fine first, as it's effects on an engine that is not running normally to begin with is unpredictable. Just a word of caution.
<font color=green>GroundingGear™ Equipped </font color=green>
Old Jan 30, 2004 | 01:07 PM
tonke73's Avatar
It's pretty common. My 6MT does that also. I took it in and they said that they couldn't duplicate the prob. Funny, I feel it about ever 15 seconds or so.
Old Jan 30, 2004 | 01:11 PM
redwillow's Avatar
20 Year Member
yeah, i think everyone has it....only when the AC is off.
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, 15% tint
Old Jan 30, 2004 | 06:31 PM
khsonic03's Avatar
It's a gurgle/occasional pop? If so, that is normal with all dual exhaust systems, and because you added the Borla, and it is now a TRUE dual exhaust, it will be even more noticeable. It is a combination of backpressure, and hearing the different exhaust pules from either side of the engine. Don't worry.
'03.5 Brilliant Silver AT Sedan, Premium, Aero Kit/Package, Sport, Winter, Stillen Air Box, Z pipe, Clear Corners, Alum. Pedals, Polk Tweeters, Clifford RSX 3.5, Gram Light 57F Pro's (on the way!)
Thebaws11
Jul 2, 2021 11:36 AM
Vqalexisz
Oct 14, 2015 12:48 AM
vamarris
Sep 26, 2015 12:56 PM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
Jnm07
Sep 5, 2015 01:16 AM
