spacer+mrev2
Old Aug 15, 2007 | 03:21 PM
Gfast's Avatar
spacer+mrev2
hey, everyone. I heard that 5/16 thermal spacer work well with mrev2, and increase horsepower for the car. I have an 04 g35, is my engine work with mrev2? if not wat kind should i get for the best mod.
Old Aug 15, 2007 | 03:25 PM
hai109's Avatar
Not with your 2004 setup...Car will run lean...MREV2 and spacer is good for the 05-07 models that have the REVUP motors.
You should try using the search button. Everyone that is new ask this question. Its been discussed so many times already. Just some advice. Search before you post. Others are not that kind...'
Old Aug 16, 2007 | 12:56 PM
dTor's Avatar
+1, search.
But the short answer is just get a spacer. I just spoke with Tony (the guy who owns Motordyne and makes the spacers and MREV2). He said an MREV2 will show no significant power gain on a non-revup engine (like what the OP has) if a spacer is already installed.
Old Aug 16, 2007 | 03:38 PM
Gfast's Avatar
thanks guys
sorry for repost this message again, but it kinda hard to search without a search engine
i will try to search again
thanks
Old Aug 18, 2007 | 10:41 AM
Hydrazine's Avatar
Hi Gfast,
Yes, you can do both but it won't give the gain in your engine like it does on the REVUP engine.
For your application I generally recommend just the spacer. This gives the best bang for the buck.
Adding a MREV2 to your engine will make another 2-6 HP through various parts of the midrange. So yes, it makes more, but for most people its not worth the added cost.
I hope this helps.
Tony
Old Aug 19, 2007 | 04:30 PM
Gfast's Avatar
thanks
Old Aug 19, 2007 | 10:38 PM
RebelinRI's Avatar
And it's "could" not "will" run lean.
Old Aug 20, 2007 | 09:08 AM
Iceman8's Avatar
Gfast, I also have an 04' with just the 5/16 spacer...the mod was noticeable right after install. Not so much the horse power gain, but the engine ran smoother, better throttle responce, cooler temps, and better gas milage. A great mod that you can feel and hear!
P.S> Install the TB shut off valve as well for cooler temps.
Good luck.
Old Aug 20, 2007 | 09:20 AM
gary c's Avatar
MotorDyne.......Tony's Toys!
If you compare mods and the cost MotorDynes spacer on an '04 is the best
bang for your buck! You could go all out and get the 1/2" spacer ISO for
max bang......but then you lose the OEM Engine cover. (won't fit)
cool_as_ice
Intake & Exhaust
Aug 10, 2018 09:37 AM
